Blow off valve
Old May 8, 2008 | 12:10 AM
53RUSSELL's Avatar
Default Blow off valve
I'm wounding if I need a blow off valve for only 4 to 6psi of boost and no intercooler to start. I'm going to rout my charging pipe similar to how Trick has his with out an intercooler. Do you think Intake temps are going to be through the roof runing here in AZ with out intercooler?
Old May 8, 2008 | 03:04 AM
thunderwagen's Avatar
With no intercooler yes your temps will be high and kill power.
A blow off is to save your compressor. When the throttle closes the compressor is still spinning and compressing air so when the air hits the throttle blade it has no where to go but back to the compressor. Which will cause the compressor to spin backwards ( which can cause damage to the compressor and lag ) a blow off is good insurance, and I would run an intercooler for sure. You can run an Ebay intercooler like alot of other board members to save some coin.
Old May 8, 2008 | 07:08 AM
Spoolin's Avatar
GFYS and STFU
Ditto on thunder's words. BOV are very important
Old May 8, 2008 | 10:10 AM
53RUSSELL's Avatar
I have intercooler already wanted see what you guys thought.
Old May 8, 2008 | 10:22 AM
53RUSSELL's Avatar
What kind of blow off valve would you guys recommend.
Old May 8, 2008 | 11:22 AM
ducky's Avatar
Im running a turbosmart and it works well. Tial is also really good. I dunno if I spelled that last one right
Old May 8, 2008 | 06:22 PM
Im running a Tial bov on mine.
Old May 8, 2008 | 06:23 PM
53RUSSELL's Avatar
I just order one be for lunch time here.
Wolftrk99
Dec 3, 2015 08:12 PM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
