best stall for 5.3 turbo?
Old Oct 23, 2012 | 01:31 PM
Skinnyman's Avatar
Originally Posted by o2camaross
So it takes that long for the turbo to spool? Is all the piping wrapped? Im running a Circle D 3000-3200 stall and Its working good for me, my best 60' was 1.60 but the stall or boost isnt my problem its traction.
How tight is yours? Mine is a 1c could that be a factor?
Old Oct 23, 2012 | 01:37 PM
Jake99's Avatar
Sounds like you need a 3600 stall and 2 step 3400, then lock third to keep your top end.
Old Oct 23, 2012 | 01:44 PM
Skinnyman's Avatar
Ill have to try the converter lock on nov 10 when I go to a quarter mile track at lena also my over-load springs are still on the truck but plan on taking them off to see if it helps transfer better. That might bring down 60ft also
Old Oct 23, 2012 | 02:04 PM
lglowe's Avatar
Iv read that the caltracs work better if the overload is out...
I think wrapping the pipes will help alot too
Old Oct 23, 2012 | 03:14 PM
Johnmaster's Avatar
MASS seller approved
My springs started to bend with the overload out, for the cal tracs to push down on the front of the leaf spring and push the axle/tire down into the pavement with axle torque, it needs some way to get it there. I dont think taking it out did me any favors. Heading back to the track hopefully sometime in the next week to see if that was the case. I have a 3400 stall and while I don't have anything similar to compare to, I like it. I need to spend some time seeing if I can lock it up in third reliably since I put an even taller gear in. Yank PY3400.
Old Oct 28, 2012 | 01:49 AM
Beatdown Z's Avatar
Laid Back
Yank builds pretty efficient converters, with the Pro Yanks likely being their most efficient ones. I would calculate converter slip before considering locking the clutch. Many Yanks are single disc and locking those at WOT will destroy them almost instantly.
Choda
Jan 22, 2026 02:03 PM
5.3Okasai
Mar 9, 2022 01:07 PM
LCHEE
Oct 24, 2020 04:10 PM
Jake99
Aug 8, 2015 07:56 AM
vmaxpro
Jul 27, 2015 10:45 PM
