best stall for 5.3 turbo?
Old Oct 23, 2012 | 09:34 AM
Skinnyman's Avatar
Default best stall for 5.3 turbo?
I have a single cab short bed 98 model pickup with a lil ole stock 5.3 and with an isky cam, nonnieselman old rear mount kit with the old magnum 76mm from lglowe I'm currently running FLT 80 with circle d 3k stall with a 2 step set at 2800. It makes right at 5.5# then ramping to 15.5# about 30 to 40 feet out the gate. Best 60ft so far is only a 1.75 and 11.52@118 thru a 1/4. If I raise the 2 step to 3k I can make around 6 to 7# of boost but its like it lugs when I leave what stall would work best maybe a 3600 or 3800 I don't want to go to loose because I do drive it occasionally. Thanks for the help
Old Oct 23, 2012 | 10:27 AM
slow67's Avatar
Gingervitis Addict
It sounds like your converter likes being flashed more than just more rpms/more boost. Why not try still leaving at 2800, but ramping in boost faster?
Old Oct 23, 2012 | 11:05 AM
nonnieselman's Avatar
Tried 2800,, it didnt help.
it takes a second for the boost to come in with the rear mount
Old Oct 23, 2012 | 11:18 AM
ZO6Ted's Avatar
How about a small shot on a switch just to flash it outta the hole? Love the setup!
Old Oct 23, 2012 | 11:20 AM
nitrous is the last resort..
Old Oct 23, 2012 | 12:45 PM
slow67's Avatar
Gingervitis Addict
Is this footbrake or transbrake? Also is boost just set to 15.5#, and it takes 30-40 feet for it to get there? Or your using a boost controller and ramping it in?
Old Oct 23, 2012 | 01:03 PM
Skinnyman's Avatar
It is with footbrake and its on a boost controller but my low setting is 8# and flip the switch and you have 15.5 haha
Old Oct 23, 2012 | 01:07 PM
So it takes that long for the turbo to spool? Is all the piping wrapped? Im running a Circle D 3000-3200 stall and Its working good for me, my best 60' was 1.60 but the stall or boost isnt my problem its traction.
Old Oct 23, 2012 | 01:26 PM
Skinnyman's Avatar
Yeah I guess so? ha none of my piping is wrapped so that could definitely be a problem I'm going to the track tonight so ill see if I can get someone with a video camera to video me and see what it's actually doing. It just feels like it kinda leaves and soon as boost hits that thing shoots out of there in a hurry
Old Oct 23, 2012 | 01:30 PM
yea the controller is on from the get go.. it just takes that long for the boost to ramp in.
