Behold the 383 shortblock
Old Jun 4, 2011 | 09:40 PM
  #111
swift700's Avatar
...and the 80E is in!
This job is cake with a good tranny jack. I lifted the transfer case up first and strapped it in as far to the rear along the torsion bar crossmember as I could. I then put the transmission in, unstrapped the transfer case and bolted it up. I'd heard that a guy had tried to put the transfer case in last and ended up having to pull the torsion bar x-member to do it.
The modified tranny x-member fit perfectly and the cooler lines were in the perfect spot. Everything is done underneath the truck except for the driveshafts and exhaust. It's a good feeling.
Old Jun 4, 2011 | 10:23 PM
  #112
swift700's Avatar
I forgot to mention, the cost of the 80E swap was around $1600 including used transmission ($400), Circle D's finest ($1050) and shift kit ($120). Everything else I did myself or got for free. Not a bad price for a badass transmission upgrade. It's still well under what a built 60E would be.
Of course, I still need driveshafts...
Old Jun 12, 2011 | 12:00 AM
  #113
swift700's Avatar
I finally got my valve seats machined and got a lot done today, even with a torn ligament in my hand. The heads went on easy even with the studs in place. There was lots and room and torquing was a snap. The blower is on but I'll need to shim some pulleys before the belt goes on. I should get quite a bit done tomorrow.
Haven't seen a comment in a while, is anyone actually following this?
Old Jun 12, 2011 | 12:09 AM
  #114
06Sierra2's Avatar
that looks amazing
Old Jun 12, 2011 | 01:58 AM
  #115
Spoolin's Avatar
GFYS and STFU
Are you gonna laser those pulley's?
Old Jun 12, 2011 | 10:18 AM
  #116
Atomic's Avatar
I have a gauge for that
Shiny!
Old Jun 12, 2011 | 12:13 PM
  #117
TIM Z's Avatar
11 sec. Truck Mod
Awesome progress bud!
Nice 80E install, yourone! trans worries are now gone !
Sexy looking throttle body!
Everything looks great!
For the drive shaft find a Duramax 4x4 truck for front shaft ( i got one from an 07 classic) And the rear i had a custom steel shaft made. Very happy with it and its about 1/2 what the big dollar aluminum ones run.
Old Jun 12, 2011 | 01:02 PM
  #118
offroadrider12's Avatar
Old Jun 12, 2011 | 02:42 PM
  #119
AKlowriderZ71's Avatar
11 Second Hall Moniter
How did the valve adjust go? I usually end up with bloody knuckles.... lol
It's looking really good! Can't wait to see a vid of it tearing up some asphalt.
Old Jun 13, 2011 | 12:48 AM
  #120
swift700's Avatar
I worked for 9 hours today. I got the pulleys lined up but it took a lot of work. The power steering pump had to be shimmed back a bit, the tensioner and blower pulleys needed shimmed and I had to take some material away from the back of to alternator pulley. All in all I think it's nearly perfect and I did it all with straight edges.
The valve adjust was a piece of cake but finding zero clearance was a bit of an issue since the lifter cups were holding so strong. They would hold the lifters down or up and that was a bit of a headache. I'm pretty sure I got it though and the 7.250 rods are about perfect. Thanks again, AK.
The engine bay is complete except for some wiring for the 100mm MAF. I don't know if I'll even run it but it's there in case I want to go that route.
The other things that need done are the headers and exhaust and the driveshafts. Exhaust should only take a couple of hours.
I'm thinking that I'm going to load a tune from a 2000 6.0/4L80 and try to work it from there. I'm not too sure when I'll get to it next but every spare minute will be spent finishing up.
Here's a crappy pic. Kinda cool, the writing on the oil cap is the same color as the engine.
