Any ProCharger guys ever run the HoB DD bracket system?
Old Apr 2, 2014 | 06:32 PM
  #61
silverado.408's Avatar
Any vids of the pull ?
Old Apr 3, 2014 | 12:05 AM
  #62
Blown06's Avatar
8 Second Truck Club
Originally Posted by Superado
1st pass = 620rwhp @ 6100rpm, 13.5#, 18 degrees of timing, 10.5 a/f...
NO belt slip.
Should reach the 700+rwhp mark by the time he's done tweaking the tune.
Nice.
Just for comparison, I got 1 pull on the dyno when I had the iron 347 and the d1sc w/8-rib. Calculated blower speed was 106% at 7000 engine rpm.
I only got one pull to 6000 due to the trans not holding. At 6000 rpm, it was making around 18-19 psi. I think I had about 16* in it at the time, on c16/pump mix. It made 695 at the tires.
Just for you to reference when you turn it up.
Old Apr 3, 2014 | 02:38 PM
  #63
Superado's Avatar
11 Second Truck Club
unfortunately, no
Originally Posted by 94 slow
That's great! What is the size of the motor? Also, 4L80E trans?
5.7L LS1 thru a 4L80e...
Originally Posted by Blown06
Nice.
Thanks!
What size compressor pulley were you running at the time?
Old Apr 4, 2014 | 12:36 AM
  #64
Blown06's Avatar
8 Second Truck Club
unfortunately, no
Thanks!
I had a measured 8.13" crank and 3.54" blower pulley. Basically an overdrive innovators west and a 3.55" RR. The 8.13" and 3.54" numbers were from an actual measurement that I took.
Old Apr 6, 2014 | 03:00 PM
  #65
94 slow's Avatar
How is the throttle responsiveness on the street? Also, are you waiting for Mr.freeze to be setup before you run a final dyno setup?
Old Apr 6, 2014 | 04:17 PM
  #66
Superado's Avatar
Fighting high IAT'S that we want to get under control first...and then add Mr. Freeze.
Got the fresh air intake completed today.
Attached Thumbnails Any ProCharger guys ever run the HoB DD bracket system?-resampled952014-04-069516-11-4595352.jpg   Any ProCharger guys ever run the HoB DD bracket system?-resampled952014-04-069516-11-5395100.jpg
Old Apr 7, 2014 | 12:24 AM
  #67
Blown06's Avatar
8 Second Truck Club
Just my opinion.........but you just killed that D1sc.
Old Apr 7, 2014 | 12:53 AM
  #68
lablackbeast's Avatar
doesn't know what quit means
Blown why is that?
Old Apr 7, 2014 | 09:03 PM
  #69
Superado's Avatar
Originally Posted by lablackbeast
Blown, why is that?
Old Apr 7, 2014 | 11:58 PM
  #70
Blown06's Avatar
8 Second Truck Club
It aint gonna like breathing through that at all. I could be wrong, but next time your on the dyno, when your finished tuning, pull it off and make another pull. It'll likely pick up significant power and boost.
Prochargers hate tubing cold air systems.
