Any ProCharger guys ever run the HoB DD bracket system?
Edit:
Dyno results - pg 8
Tuning update - pg 6
Progress pics added - pg 3
Also, if anyone is interested in getting this set-up as well...please ask for Shaun and tell him that you saw it here.
They are interested in the feedback from you guys and debating on whether to make a complete kit with FMIC piping for the 99-02.
Thanks!
They make one for the TBSS and the 03-06 trucks...not sure what would be different for the 99-02 trucks.
It mounts the ProCharger on the passenger side and uses a dedicated 8-rib from compressor to crank. Factory 6-rib serpentine set-up remains stock.
These guys are located in Lenexa, KS...same as ATI ProCharger...so I can only assume they have a good relationship with each other.
Dyno results - pg 8
Thanks!
It does put a dent in the pocket, for sure.
The only other things out there are the ATI Performance Products 8-rib & 10-rib set-ups...they're $1295 and not DD systems.
Thanks for sharing!
Thanks for sharing!
The pro to this kit is the dedicated belt. You would never have to worry about popping a belt and over heating again, unless you a re running a E water pump. If i had a vehicle sitting I would moc one up..
I've messaged them on a couple of forums and FB but no reply.
Messaged "BoostFreak" here as well...looks like he hasn't been on pt.net in quite a while though.
Just messaged them on their website...maybe I'll hear from them soon.
I'll give Fast Motorsports a shout as well...thanks!
house of boost dot com
I heard from Fast Motorsports earlier this week via FB...very informative.
I just received an e-mail from Shaun @ HoB this morning as well...also very informative.
