8 rib pulleys , where do you get them from?
Old May 26, 2011 | 11:43 PM
idahoblkss's Avatar
Default 8 rib pulleys , where do you get them from?
8 rib pulleys where are you guys getting them from and what are they costing? Im looking for the alt, power steering, and crank pulleys. I believe the idlers will fit a 8 rib and I got a Hd tensioner that's 8 rib already.. thanks
Old May 27, 2011 | 12:06 AM
Mangled03gmc's Avatar
Baltimore Whore
ATI, or innovators west... Or on here.. I got my IW kit on here for CHEAP.....
Old May 27, 2011 | 12:31 AM
idahoblkss's Avatar
Ok I was looking on innivators west and not sure if I should get the over drive or under drive or just keep it standard size for the crank pulley?? What are the pros and cons?
Old May 27, 2011 | 12:40 AM
Baltimore Whore
The 10% is the way to go, it spools the blower faster..
Old May 27, 2011 | 12:45 AM
idahoblkss's Avatar
10% over drive or under drive? Are there any cons to this?
Old May 27, 2011 | 12:49 AM
Baltimore Whore
Overdrive.. I was not aware they offer a under drive kit, as that would spin the blower slower.. Have not heard any problems with the overdriven ones, i would think the other pulleys with the kit are sized to spin the accessories at normal rpms
Old May 27, 2011 | 01:01 AM
idahoblkss's Avatar
So I would assume it would create another pound of boost or so too? Did you use your stock idlers?
Old May 27, 2011 | 07:47 AM
CAM-T's Avatar
Really no cons going with the 10% overdrive balancer. On the plus side you can get more boost if you're running the 2.7 pulley, which I believe is the smallest diameter S/C pulley you can run. Innovators has the best crank balancer IMO, and LeftCoast32 has a killer pulley system for it. You can buy both from Joe, whom BTW has top notch customer service as well. Here's a pic of Joe's pulley system with the Innovators balancer. Note the HD tensioner pulley is aluminum as well.
Old May 27, 2011 | 09:03 AM
moregrip's Avatar
what a rush!
If it was me, I'd buy my pulleys from Joe......he and his new partner have some very desirable changes incorporated into their pulleys. For instance: if you look in the photos above the pulley surface is hard anodized, also bearings are in optimal position, larger bearings, etc etc.
Old May 27, 2011 | 11:21 AM
idahoblkss's Avatar
Those look nice what are his kits going for? I wont need a couple of those pulleys cause im procharged so it might be a lil cheaper maybe
