8 rib pulleys , where do you get them from?
8 rib pulleys where are you guys getting them from and what are they costing? Im looking for the alt, power steering, and crank pulleys. I believe the idlers will fit a 8 rib and I got a Hd tensioner that's 8 rib already.. thanks
ATI, or innovators west... Or on here.. I got my IW kit on here for CHEAP.....
Ok I was looking on innivators west and not sure if I should get the over drive or under drive or just keep it standard size for the crank pulley?? What are the pros and cons?
The 10% is the way to go, it spools the blower faster.. :nod:
10% over drive or under drive? Are there any cons to this?
Overdrive.. I was not aware they offer a under drive kit, as that would spin the blower slower.. Have not heard any problems with the overdriven ones, i would think the other pulleys with the kit are sized to spin the accessories at normal rpms
So I would assume it would create another pound of boost or so too? Did you use your stock idlers?
1 Attachment(s)
Really no cons going with the 10% overdrive balancer. On the plus side you can get more boost if you're running the 2.7 pulley, which I believe is the smallest diameter S/C pulley you can run. Innovators has the best crank balancer IMO, and LeftCoast32 has a killer pulley system for it. You can buy both from Joe, whom BTW has top notch customer service as well. Here's a pic of Joe's pulley system with the Innovators balancer. Note the HD tensioner pulley is aluminum as well.
Attachment 148388 |
If it was me, I'd buy my pulleys from Joe......he and his new partner ;) have some very desirable changes incorporated into their pulleys. For instance: if you look in the photos above the pulley surface is hard anodized, also bearings are in optimal position, larger bearings, etc etc.
Those look nice what are his kits going for? I wont need a couple of those pulleys cause im procharged so it might be a lil cheaper maybe
