6.3 Stroker 94mm Turbo Ran a shameful 13.4
Old Dec 28, 2015 | 09:04 PM
  #51
GMCtrk's Avatar
Originally Posted by 20SS06
I have M&H 275/50R17 drag radials on stock rims. They did not spin at all in 4WD nor 2WD not just at the track but even in the street.
You're seriously down on power if you can't spin those small tires.
Who tunes your truck?
Old Dec 29, 2015 | 08:54 AM
  #52
Turbo09's Avatar
^ I agree this could be the biggest issue, I know before my truck was tuned properly it was very slow to spool and didn't have nearly the top end power it ha now.
Old Dec 29, 2015 | 12:24 PM
  #53
Originally Posted by Byrdman11
Are you brake boosting the truck?
Nope. Never tried.
Old Dec 29, 2015 | 12:35 PM
  #54
Usually it's Mike from NEP. But I replaced the ECU and had a tuner here do a half-assed tune after this build. I am in the process of tuning with Mike again.
Old Dec 29, 2015 | 12:37 PM
  #55
That's good to hear. My current tune is definitely out of whack.
Old Dec 29, 2015 | 12:48 PM
  #56
Atomic's Avatar
I have a gauge for that
You will never get a good launch if you don't get that big turbo whistling from the start!
Old Dec 29, 2015 | 01:42 PM
  #57
Would a 3600 stall help achieve that?
Old Dec 29, 2015 | 01:55 PM
  #58
Atomic's Avatar
Probably, but tuning a converter for your setup is going to be tricky. You want it loose enough to allow enough air through the engine to start to spool it, but you want it to couple very hard early in the rpm band to not blow through based on where you want to shift.
Old Dec 29, 2015 | 08:44 PM
  #59
Choda's Avatar
I have to think this alone will make a huge difference. Have mike tune it and re run it. Change nothing else and see what happens.
Old Dec 29, 2015 | 08:46 PM
  #60
George C....'s Avatar
Formerly ScreamingL
Where are you located
