6.3 Stroker 94mm Turbo Ran a shameful 13.4
#51
#54
Probably, but tuning a converter for your setup is going to be tricky. You want it loose enough to allow enough air through the engine to start to spool it, but you want it to couple very hard early in the rpm band to not blow through based on where you want to shift.
#59
I have to think this alone will make a huge difference. Have mike tune it and re run it. Change nothing else and see what happens.
