6.3 Stroker 94mm Turbo Ran a shameful 13.4
Old Dec 29, 2015 | 09:11 PM
  #61
ZO6Ted's Avatar
No offence intended whatsoever but unless you brake boost its understandable why you've got a 2.37 60'. Totally different animal than that Whipple you had. You gotta build some boost or its gonna leave with probably 2-400 less lbs/ft than you could and feel like a dog.
Old Dec 30, 2015 | 11:15 AM
  #62
kbracing96's Avatar
Originally Posted by George C....
Where are you located
Originally Posted by 20SS06
Would it be better if I remove it? It's pretty dusty here in the UAE.
My guess is across the pond in UAE.
But like I told you in the email, I think that turbo is way to big for a street truck. Probable takes a month of Sundays to spool and leaving with no boost on a soft tune isn't helping at all!
Old Dec 30, 2015 | 11:20 AM
  #63
Better Convertor and tune will help for sure.
But you really need to look at a smaller more efficient turbo and cam that will work with that small bore long stroke combo.
Old Dec 30, 2015 | 01:57 PM
  #64
Originally Posted by Atomic
Probably, but tuning a converter for your setup is going to be tricky. You want it loose enough to allow enough air through the engine to start to spool it, but you want it to couple very hard early in the rpm band to not blow through based on where you want to shift.
Hmmm. That makes sense. We'll have to see later I guess.
Old Dec 30, 2015 | 01:58 PM
  #65
AbuDhabi, UAE
Old Dec 30, 2015 | 01:59 PM
  #66
Originally Posted by Choda
I have to think this alone will make a huge difference. Have mike tune it and re run it. Change nothing else and see what happens.
Let's hope so! In the process of tuning right now as we speak.
Old Dec 30, 2015 | 02:00 PM
  #67
None taken. I understand. I tried but the car would set the tires loose at around 1500 rpm LoL. Stock converter woes..
Old Dec 30, 2015 | 02:02 PM
  #68
You are right. Let's see what happens now after the tune though and I'll take it from there.
Old Dec 30, 2015 | 02:03 PM
  #69
True. But I'm hoping that changing turbos would be the last resort.
Old Dec 30, 2015 | 02:11 PM
  #70
Atomic's Avatar
I have a gauge for that
If you click that button next to the "Quote" button you can quote a bunch of posts at once if on the last post you click "Quote". They will all appear on one box.
