6.3 Stroker 94mm Turbo Ran a shameful 13.4
Old Dec 25, 2015 | 02:36 AM
Default 6.3 Stroker 94mm Turbo Ran a shameful 13.4
Hi guys,
I was excited to test out my new setup last night at the track only to be shocked by getting 13.4 on 10psi and 13.3 on 13.5 psi!! I ran an 11.7 on my last setup with a 2.3 whipple and meth.
List of current mods:
Stock 3.42 gears
Bullseye Power 94mm BatMoWheel turbo with 1.50 A/R
4 downpipe into 3.5 inch muffler and cat
ID1300 injectors
PRC Stage 1 LS6 Heads
Custom Cam
6.3 forged stroker (383ci)
What do you think the problem could be? Is it the stock converter and 3.42 gears? or is it something else?
Any input will be really appreciated to get this pig moving.
Thanks
Old Dec 25, 2015 | 07:08 AM
06 4.8's Avatar
The turbo is about 20 mm too big. What was the 60' and 1/4 mph? That will help out more
Old Dec 25, 2015 | 07:48 AM
On the 13.4 run
60ft: 2.357
MPH: 111.6
On the 13.3 run
60ft: 2.509
MPH: 114.69
Old Dec 25, 2015 | 08:21 AM
06 4.8's Avatar
Is this a single cab truck? The 60' needs some SERIOUS work. Get a converter to match your set up. The mph is the same as mine and I run 11.8 but with a 1.7 60'
All I have is a simple 6.0 with a small shot. I'm thinking it may be tune related only going 114 with your set up
Old Dec 25, 2015 | 08:42 AM
Yes, it's a single cab. Was thinking of getting Circle D's multidisk 3000 stall converter. Would that suffice? What about 4.10 gears? I will look into the tune as well to make sure everything checks out.
Old Dec 25, 2015 | 10:06 AM
George C....'s Avatar
Formerly ScreamingL
Lets start off with whose turbo kit? You stated 4" manifold which has to be a typo
Old Dec 25, 2015 | 10:30 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by 20SS06
Hi guys,
Stock 3.42 gears
94mm turbo with oversized A/R
4 inch manifold and downpipe into 3.5 inch muffler and cat
ID1300 injectors
Custom Cam
Thanks
So you have a custom can and a stick convertor?
Like George ask who's turbo kit need some info there.
Oversized AR? What size AR? What size exhaust wheel?
Who's turbo?
Looks to be a few mismatched parts here.
Old Dec 25, 2015 | 11:34 AM
Choda's Avatar
OH man. I hope you can get this figured out. I'd be pretty upset too
Old Dec 25, 2015 | 12:16 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
You have to realize the first 60 feet is the most important part of the 1/8 & 1/4 mile ET. You can get a pretty good idea how much power you're making by the trap speed.
Old Dec 25, 2015 | 02:37 PM
It's a custom kit with all piping custom fabbed locally. Sorry for the typo, I meant the downpipe was 4". The turbo is a Bullseye power 94mm. I'm also running a Turbonetics Godzilla BOV and a TurboSmart 60mm Wastegate.
