408ci/TVS2300/LSA heads build
Old Jan 30, 2011 | 08:12 PM
  #101
03sierraslt's Avatar
Originally Posted by Turbo-T
Why are you running the 4L80e why not run the 4L65e or the 4L60e? lighter and less hp to turn it up. Just asking and wondering I don't know it all??
Because the 4L60, 65E's are weak. 80E is much stronger.
Old Jan 30, 2011 | 08:14 PM
  #102
1SlowHoe's Avatar
Destroyer of Transmissions
I got tired of replacing them I did have a 65E from FLT that was holding strong but a broken driveshaft on the dyno at 140mph destroyed that one. With a 6000lb truck and making 500 lb/ft I don't see any 60E style trans holding up. At the 600+ I'm shooting for here, no way I'd run a 60E.
Old Jan 30, 2011 | 08:25 PM
  #103
Turbo-T's Avatar
well I see the point and I knew I would hear that. Is his truck a full size 4 door truck? My truck is a short wheel base but I have only put 1 tranny in it the and up graded it to the beast with a shift kit and springs. I have mad alot of passes and itf it goes out the next day It only cost about 600.00 to put it in again. Maybe this go around I will try a 4l80e and see if it will last as long. But with the horsepower I have it is not much I have a 125 shot and a 6.0lq4 and have got best time 11:64 1/4 maybe I could step up the horse power and get the same time with the 4l80e
Old Jan 30, 2011 | 08:34 PM
  #104
1SlowHoe's Avatar
Tahoe. Sometimes on 24's. She's a fat girl.
Old Jan 30, 2011 | 08:50 PM
  #105
Turbo-T's Avatar
well that said it all 24's and a Tahoe I did not look well. LOL.... I see why the 4l80e needs to be in place. I think maybe an Allison out of my diesel would help!
Old Jan 30, 2011 | 08:56 PM
  #106
Atomic's Avatar
I have a gauge for that
In all fairness, my pb level 3 60e held up to my 408 with tvs1900 making about 600hp in a 6400lb truck, so they can live, but how long is anyones guess.
Old Jan 30, 2011 | 09:04 PM
  #107
Turbo-T's Avatar
Smile
Well I see the point I just wonder how much power will it rob? Any clues I will have to check this tread out later have to get some sleep. Thanks!!!!!
Old Jan 31, 2011 | 08:58 PM
  #108
1SlowHoe's Avatar
Originally Posted by old motorhead
Cubes eat overlap.
Looks like you were right
Originally Posted by Pat G
Because a 408 will require 10 degrees more overlap than a 6.0L to behave the same, 3 degrees of overlap in a 408 is equivalent to -7 degrees of overlap in a 6.0L. I hope this makes sense to you. You will be very happy with the performance of this cam.
Old Feb 1, 2011 | 06:40 AM
  #109
old motorhead's Avatar
Have you started turning that sweet pile of parts in to a sweet motor? If not.....get it done already!
Old Feb 1, 2011 | 03:12 PM
  #110
1SlowHoe's Avatar
No cam yet
