4.8L 80mm Single Dirty Grandpa Truck Build
Old Sep 25, 2014 | 01:00 PM
  #281
oakley6575's Avatar
Hmm, I had stock values in that table. Maybe that is contributing to my shifting problems from 1st to 2nd gear. I have it set to shift at 4000rpm and it still bounces off the 7000rpm limiter...
OP, are you going to rebuild the trans yourself?
Old Sep 25, 2014 | 01:16 PM
  #282
Atomic's Avatar
I have a gauge for that
I have mine set at 5200 and it finally happens around 6200. I think its a time/power thing.
Old Sep 25, 2014 | 01:25 PM
  #283
oakley6575's Avatar
Definilty a power thing. At 5lbs of boost, it shifts on the money wherever I tell it to. Once it is upped to 10+psi, I just can't get it to shift without lifting my foot off the pedal and getting back in it after it shifts to 2nd gear... OP, I'd talk around to some shops about this issue and see if they recommend any special parts to fix it before you starting building yours.
Old Sep 25, 2014 | 02:44 PM
  #284
boostedsl2's Avatar
Yes sir.... I used to be a mechanic lol, so I can figure it out. I do have a couple idiots that are current mechanics for buddies. They haven't done 4l80's but, they have done a bunch of FWD autos and such.
Old Sep 25, 2014 | 02:49 PM
  #285
boostedsl2's Avatar
Yep, I have the same issue. Have (had) mine set for 5200 to get it to shift by 5800. gets worse with more boost
  #286
boostedsl2's Avatar
Will do. Thanks.
Old Sep 27, 2014 | 07:22 AM
  #287
Beatdown Z's Avatar
Laid Back
Do you guys have the MPH set correctly too?
Mine shifts right at the MPH and RPM I have it set to.
Old Sep 29, 2014 | 05:47 AM
  #288
boostedsl2's Avatar
On my logs the ecu shows a shift at the right time (mph & rpm) but it'll show 3rd gear at 5800 for a split second and then drop to whatever it's supposed to be. I chalked it up as the ecu commands and the mechanical lags behind. Might be why my 4l60 is toast now lol.
I was also reading on hp tuners. I believe my 60 was in lock up between shifts (factory?) Which evidently is not good and I had stock shift times still plugged in.
Anyone have comment on lockup?
Old Oct 5, 2014 | 08:17 AM
  #289
Atomic's Avatar
Torque converter lock? Dont do it.
Old Oct 6, 2014 | 07:47 AM
  #290
boostedsl2's Avatar
Ok. So i'm an automatic/torque converter idiot. I assume you mean no lock during shifts but lock in gear? I would imagine if you didn't want to lock at all, those tripple disk billet converters are not really needed (the tripple disk portion).
I hear a lot of guys saying they don't want a locking converter. I assume this is more for a drag setup?
Any info would be helpful.
Thanks,
