4.8L 80mm Single Dirty Grandpa Truck Build
Old May 6, 2014 | 03:29 PM
  #161
Atomic's Avatar
I have a gauge for that
My cruising egt at the turbo wss about 1450 with 45 degrees of timing. The log wss always glowing if that tells you anything.
Old May 6, 2014 | 03:32 PM
  #162
Chevy_King1500's Avatar
have you tried to add more fuel instead of timing?
Old May 6, 2014 | 03:38 PM
  #163
timmay208's Avatar
i put a pyro in one of my subarus, it would cruise down the hwy at 80mph and run 1450-1500 deg egt pre turbo, that is pretty avg for gas vehicles i think
Old May 6, 2014 | 08:36 PM
  #164
jtomasik's Avatar
Registered User
Boosted, thanks for the info on the spool valve. I think I might go that direction. Was at first targeting a 76mm turbo counting on the initial hit at about 2500r's then achieving 600 rwhp when it max's out. But, with the spool valve, I might be able to go bigger yet still pull down low.
Old May 6, 2014 | 09:58 PM
  #165
boostedsl2's Avatar
BW 475 will get you up near 1000whp no problem. I mapped it for you figuring you've got 85% VE. Most dyno sheets I've seen with stock engines work out to around that. If you add an intake and cam, you'd be up in the 90-95% range. All that would do is shift your required air to the right, which you'd be off the more efficient islands for 6500 rpm. Assuming you've got a big enough intercooler, it wouldn't be a problem.
Old May 6, 2014 | 10:12 PM
  #166
boostedsl2's Avatar
Older T76....
Old May 6, 2014 | 10:24 PM
  #167
boostedsl2's Avatar
Here's why 80mm are laggy on 4.8L's lol
Notice how 2000 & 3000 rpm aren't even on the map. Holds true to the fact considering I don't see boost until 3200 rpm.
Old May 6, 2014 | 10:28 PM
  #168
boostedsl2's Avatar
S480 on 6.0L with intake and cam (assuming it helps haha) 95% VE. 80mm is a pretty nice turbo for an efficient 6.0L.
Old May 6, 2014 | 10:29 PM
  #169
GMCtrk's Avatar
A couple years ago I took a ride in Smokeshow's nnbs ex cab with a T6 S475. Thing pulled hard but definitely had lag. And that was on a 6.0. I laugh everytime I see someone on tech claiming their S480/4.8/5.3 has no lag.
Old May 6, 2014 | 10:37 PM
  #170
boostedsl2's Avatar
I agree. its a turd for sure. It'll get better with a intake, cam and some nitrous lol.
