4.8L 80mm Single Dirty Grandpa Truck Build
#171
I have the S475 83/74 turbine on mine and it's responsive for sure but I have issues with the boost dropping off up top. I haven't had enough time to figure out if it's a wastegate/boost controller issue or turbine sizing. So I'm considering upsizing depending on what I find and dealing with more lag.
#173
#174
I'm not sure on the current power level. It made 542 rwhp on 8 psi. I've been hitting it at 16 psi but the boost was falling down up top. Shift at 6250 eve though it's commanded at 4600. I don't rev higher for transmission longevity.
I made some adjustments to my boost controller to stabilize the boost but haven't had a chance to test it yet.
#175
#176
#177
I have the same problem. Commanded at 5200 and it'll shift at 5800. The ECU thinks it's in 2nd after the command, but logs will show it 2nd gear at 5800 for a second before it shifts.
#180
