2014 Sierra RCSB Z71 On3 Turbo
#111
Well a shorter length should raise the speed slightly but I'd need a side by side picture of a RCSB and a CCSB to see how different the pieces are made. Either way the aluminum shafts are like tin foil with cardboard liners to reduce NVH and the steels shafts are made pretty much the same way.
The front shafts don't seem to ever have this problem as they are built differently.
A 3in thick walled steel shaft that's high speed balanced should be more than enough to handle speeds above 120-130.
#114
Here is a RCSB truck I remember seeing on youtube, stock steel shaft on the dyno and it went boom.
https://www.youtube.com/watch?v=M8Kjuk6KXMA
#115
Now, are you referring to just 1500 and not 2500 models? I had over 15 pulls on my 2500 with a 10” lift in 37’s my drive shaft is aluminum.
#116
I think their critical speed is a bigger issue. I believe stock height trucks with speed limiters removed have had this happen at high speed too. I think a 2 piece conversion is the solution. 4WD trucks have a shorter DS with a higher critical speed.
http://spicerparts.com/calculators/d...rpm-calculator
#117
awesome power for only 8 psi. Hows the fuel system keeping up? Does your tuner think 10 psi will not be an issue?
I 2nd the driveshaft question. I a regcab 4x4 has the shortest driveshaft available. Along with being stock ride height. both are in favor of it being fine.
I have an nnbs ecsb 4x4. alum D.S. and been 150mph a dozen times. The shafts i see breaking are 2wd and mostly crew cabs also have lowered trucks.
#118
Currently I've developed a massive exhaust leak. I either blew the header gasket, lost a V-bands clamp, or perhaps I forgot to tighten the aux wideband plug in the downpipe. It's in the shop cooling down now and either after work today or tomorrow I'll get in there and see what's going on. I am afraid it is likely something very close to the head as driving down the road it's stinging my eyes, windows up or down.
Thanks all for the concerns on the driveshaft. I will likely looks for a quality replacement unit once I get things sorted anyway. Sounds like affordable insurance.
I did get the BOV spring changed. I was curious what the actual spring pressure difference was and had a valve spring tester staring at me so here's the "-6psi" spring(looks to be plain/bare steel w/ black stripe) that came from Tial and the "Yellow" (-11psi) compared. I swapped to the Yellow but as I've done more driving, I noticed that my in-gear idle vacuum is more around -19in/hg indicating the plain/-10psi spring.
When I swapped springs, I noticed less hunting and less boost drop on shifts(was pretty bad before) but then almost immediately the exhaust leak hit. The plain spring should be in later today and I'll compare that one as well if I can get the exhaust issue sorted. Going to pick up a couple of extra manifold gaskets just in case at lunch.
Stiffer spring necessitated using the vice to get the BOV housing buttoned up.
I also am finding a few places where lines are rubbing. My strategy has been(last pic) to cut hose and split it lengthwise and tie it to the line that is rubbing, acting as a shield. Do you guys have a better hack for such a thing?
#120
