2 bar MAP questions
Old Feb 6, 2012 | 12:46 AM
TXjeepTJ's Avatar
Default 2 bar MAP questions
I'm upgrading to HP tuners PRO so I can input my wideband to the computer.
I also want to upgrade to a 2 bar MAP. Do I just buy one of these (for example, go to google and search for "silverado 2 bar map" and buy it) and install it and that is that? I'm also having trouble finding one to begin with (if someone could point me in the direction for that )
or will I need to tune it once I install the 2 bar map? (I do not have a license for tuning my PCM yet, so I haven't touched any programming with it)
My guess is, is that the PCM OS will still act like it is a 1 bar MAP (ignore + gauge pressures) until I register/tune my PCM and change the OS to a 2 bar MAP.. correct?
Old Feb 6, 2012 | 12:50 AM
smokeshow's Avatar
Mod with training wheels
Correct. Need linear and offset values for the sensor and you're good to go.
Old Feb 6, 2012 | 07:51 AM
robbyredneck's Avatar
if your using the truck mani. then a cobalt 2 bar bap will drop in i got mine from my buddy that sells generic parts it was a airtex unit and worked great. then when you get hp tuners you will need to use 4 credits. 2 to register your vehicle and 2 to upgrade to a 2 bar os. there is a great video tutorial on hptuners website for the upgrade. do not use the 2bar with the 1bar tune. also there is still no way to log your wideband with the mpvi pro alone. you will always need to have your laptop to plot your wideband against your ve but the pro makes it possible. also make absoulutly sure that your truck goes into pe before be or else it won't enrich under boost (for certain os's).
good luck, you will spend alot of time on hptuners forum.
Old Feb 6, 2012 | 11:45 AM
X2 on the cobalt SS 2 bar map sensor... That is what I used on my truck.
Old Feb 6, 2012 | 11:59 AM
graysilverado5.3's Avatar
X3 on the cobalt ss sensor. Are you going to do your own tuning or are you going to send your logs to Nelson?
Old Feb 6, 2012 | 07:07 PM
TXjeepTJ's Avatar
I plan on doing my own tuning, but for now I have nelson's tune in still and will keep that tune until I feel I am comfortable enough to tune on my own
Robby-- thanks for the info, I had no idea I need to use up 2 credits to upgrade the OS... damn.. I only have 4 credits left on my interface. I've already added the link to how to upgrade to a 2 bar map off the hp tuners little flash videos, that will get me started and I'm really thankful for that
Thanks guys for suggesting the cobalt SS MAP! that takes out the stress of tracking down a 'silverado 2 bar map'
Old Feb 11, 2012 | 06:08 PM
fastjweb's Avatar
Ill PM you where i got mine
Old Feb 11, 2012 | 06:22 PM
Silverado777's Avatar
Part number 12615136
chopperloco
Jul 10, 2016 10:45 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ketis
Jul 23, 2015 12:37 PM
jrplz
Jul 9, 2015 12:07 AM
