smokeshow dyno
Mod with training wheels
Got the truck up on the rollers tonight. Had some technical difficulties with keeping the converter locked, but it made 530hp at 5700 and 661tq at 4700. For some reason it wouldn't stay locked over 5000rpms, so the power numbers aren't so accurate. But torque is right on with the locked converter.
I will try to find a scanner to post up the graph. Have videos too. Will update later...sleep now!
This is one of the runs, not sure which one it was. But the sheets all looked similar...torque peaked, then slowly fell off as RPM climbed cause the turbo can't keep up with the flow at this boost level. Peak torque at 10psi, fell down to 7.5-8 at the end of the run. Interesting to note though, the horsepower graph began to level out and begin climbing again at the end of the run.... I think it could put down some really nasty numbers were it not for all the little quirks popping up.
