Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Isky triple 12 cam 5.3 NA results
Old Nov 20, 2013 | 05:07 PM
black00chev's Avatar
Slowest turbo build ever!
Default Isky triple 12 cam 5.3 NA results
Finally getting around to putting this up. This was the best run out of like 6, during dyno tuning, before a lifter started to go bad and they got the final tune dialed in. I think I could easily spin 6200 before the power drops off hard. It made 299.4rwhp @ 5600 and 310.5rwtq @ 4300.
Old Nov 20, 2013 | 05:33 PM
snakeatinZ's Avatar
Him downstairs
Do you have any base numbers before the cam
Old Nov 20, 2013 | 06:06 PM
smokeshow's Avatar
Mod with training wheels
That's pretty good torque under 2000rpm.
Old Nov 20, 2013 | 06:08 PM
Vortec350ss's Avatar
Every dyno is different, but the 5.3 with bolt on mods only is usually good for only around 250 I think... I'd be happy with those numbers!
Old Nov 20, 2013 | 06:41 PM
TIM Z's Avatar
11 sec. Truck Mod
X2 exactly , great numbers .
Old Nov 20, 2013 | 07:01 PM
03sierraslt's Avatar
Maybe I am missing something, where does his dyno show RPM?
Old Nov 20, 2013 | 07:16 PM
TIM Z's Avatar
11 sec. Truck Mod
Good question , looks like bottom is run time , kinda fools ya into thinking its RPM until you see peak at 8000 Lol !
Old Nov 20, 2013 | 07:40 PM
No . I forgot to ask before they tore into the cam swap. But based on my previous best 1/8mi et and mph plus weight, it shows crank hp to be around 300-310 so figure 15% drivetrain loss and it puts me around 260rwhp before the cam and milled stock heads.
RPM is on the right and is shown by the green line that pretty much follows the HP curve. Looks like im making 290/290 @ 5250. Not bad I think, considering im still running through stock manifolds and cats. I can now see why this is such a good cam with a turbo.
Old Nov 20, 2013 | 08:06 PM
smokeshow's Avatar
Ah, saw the 2000 and assumed it was rpm.
Old Nov 20, 2013 | 08:16 PM
In any case you're right though. Torque is 260-265 at 23-2400.
Too bad I cant feel it with this knock sensor low voltage code I keep getting.
