Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Isky triple 12 cam 5.3 NA results
Old Nov 20, 2013 | 08:18 PM
03sierraslt's Avatar
Originally Posted by smokeshow
Ah, saw the 2000 and assumed it was rpm.
I did also, that is a weird print out. Non the less, good numbers.
Old Nov 20, 2013 | 09:10 PM
Choda's Avatar
Wow a Cam said to be for boost is making great NA power
Old Nov 20, 2013 | 09:18 PM
Vortec350ss's Avatar
And I forgot its through stock manifolds. Makes those numbers even better!
Old Nov 20, 2013 | 10:12 PM
black00chev's Avatar
Slowest turbo build ever!
Once I get the knock sensors replaced, im tempted to make an ORY to delete the cats and open the exhaust up to 3" at the Y. It probably wont be until sometime mid to late next year before I get the turbo started so why not right? Should be worth I think...
Old Nov 20, 2013 | 10:31 PM
Driver311's Avatar
Ya this truck has 330-340whp easy with a nice setup of headers and ory. These motors need to breathe and your basically choking it up with your current setup. Great numbers for current setup. Maybe you should buy my pacesetter 1 3/4 headers so I can get the 1 7/8 ones.
Congrats.
Edit. Just seen your boosting it. So no headers LOL
Old Nov 21, 2013 | 05:41 PM
Yea this cam works really well it seems like so far. KPA when WOT stays between 90-95. I think yall managed to convince me to get the ORY done asap. Worst case instead of a whole new piece, Ill just weld a straight pipe in where the cats are.
Since its hard to see or make sense of the graph, I took the time and figured some stuff out on it. These numbers are rounded off slightly to make it easier.
2s mark is 2400rpm, 120hp, 255tq
4s mark is 3100rpm, 160hp, 275tq
6s mark is 3700rpm, 205hp, 290tq
8s mark is 4300rpm, 255hp, 310tq(peak)
10s mark is 4975rpm, 285hp, 295tq
12s mark is 5575rpm, 300hp(peak), 285tq
and by my guess, 6100rpm would be 285hp, 265tq
Im really happy with the numbers, now just gotta get the knock sensor issue fixed so I can really enjoy it. 10-15* of timing at WOT until 3-3500rpms isn't very fun.
Old Dec 2, 2013 | 05:41 PM
ls1prayer's Avatar
this run is on 93 octane?
Old Dec 2, 2013 | 08:33 PM
Yup good ole BP 93 octane.
Old Dec 10, 2013 | 09:19 AM
Pontiac Derek's Avatar
Nice, I've spent a lot of time researching drivetrain loss for 4x4's and with a stall converter its normally between 22-28* percent power loss and 18-22* with the vert locked
Jmho
Denali08
Aug 9, 2015 04:34 PM
Sexyrado327
Aug 2, 2015 04:08 PM
MS3Z
Jul 30, 2015 06:17 PM
steves86ta
Jul 28, 2015 10:21 AM
Atomic
Jul 11, 2015 03:51 PM
