TIME SLIP DATABASE
new times with Whipple
Old Oct 1, 2005 | 07:46 PM
01Tahoetwinscrew's Avatar
Default new times with Whipple
Finally got a chance to go to the track with my #44 Multec injectors and my LS-1 edit tune. I had the timing at a very conservative level and dialed in the IFR about a month ago and everything seemed to be running well. My previous best was 13.11@100 with stock aux whipple injectors. The air was great at MIR last night(55 and barometer above 30) and the track was hooking sufficiently for good #'s. Here is the breakdown of my best pass:
60'-1.801
330'-5.252
1/8-8.191@83.06
1000'-10.776
1/4-12.987@101.71
I was amazed when I picked up my time slip and so was everyone else at the track. This run was with about 9psi(3 1/8") pulley and 100 octane to make sure it doesn't detonate. I believe that I can go faster with a little more timing and getting the fueling perfect. I also have a 2 7/8" pulley that I haven't used yet which should be around 11 psi.
Old Oct 2, 2005 | 12:05 AM
greentahoe's Avatar
This is in a RC or a Tahoe? Great numbers either way!
Old Oct 2, 2005 | 10:42 AM
Ruffrider5.3's Avatar
What kind of air / fuel you running?
Old Oct 2, 2005 | 12:01 PM
Mort's Avatar
Cool
Congrats, great times. and more to come...
Old Oct 2, 2005 | 09:22 PM
My Tahoe is gone and these times were in my '00 RCSS pickup. I don't know the exact A/F ratio but I had no knock and the 02's were in the .890-.910 range the entire run.
Old Oct 2, 2005 | 10:17 PM
BigTex's Avatar
Ha, I was thinking it was in your old Tahoe as well. Its impressive in a truck, but I was going to be amazed at your tahoe jumping into the 12s. As I recall, it had just dipped into the 13s.
Welcome to the 12s.
Old Oct 3, 2005 | 02:26 PM
What kinda mods did you have when you were in the 13's?
Where is the best place to get pullies?
Old Oct 3, 2005 | 08:17 PM
With exactly the same Whipple supercharger on my '01 Tahoe my best e.t. was 13.93@97.4 with a 2.04 60'. This was with all of the Whipple craptronics, stock PCM tuning, same pulley (3 1/8") and 100 octane. The Tahoe weighed almost exactly 1000 lbs more than my pickup. I purchased the pulley directly from Whipple as I believe that this is the only place you can get them for the Whipple unless you find them in the classified section or on Ebay.
thunder550
Oct 8, 2015 04:53 PM
kr1s
Aug 24, 2015 05:34 PM
MS3Z
Jul 30, 2015 06:17 PM
ou812sm
Jul 18, 2015 01:12 PM
D1SCSS
Jul 3, 2015 06:08 PM
