TIME SLIP DATABASE
New PB!! 12.3 at 104
Old Aug 12, 2010 | 01:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Arrow New PB!! 12.3 at 104
What are my chances of getting into the 11's with shorter stickier tires? Currently running 3.73 gears with 31.2 inch tires. I'm crossing the finish line at 4650 rpm in 3rd gear.
Old Aug 12, 2010 | 02:21 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Why not throw a freer flowing exhaust on there I bet that would be good for 2 tenths by itself easily if not more.
Old Aug 12, 2010 | 02:26 PM
Oh, I'm shifting at 6400, and my IDC is 102%. I'm still rocking the 76mm throttle body, stock manifolds, stock y-pipe with cats, and a kink-bent 2.5 inch cat-back. If I open any of that up, I'll need bigger injectors. I don't really want to do that with this setup. This whole setup should be going into our Yukon this winter, with a new build planned for my truck.
Old Aug 12, 2010 | 02:49 PM
charcold-bowtie's Avatar
Word. Pretty impressive times for the overall set up tho! congrats
Old Aug 12, 2010 | 03:20 PM
pittman's Avatar
You will be knock-knock-knockin on 11's door I would think !!!
Old Aug 12, 2010 | 03:25 PM
fastnblu's Avatar
Way to go Roger!!! Congrats!
Nice R/T & 60' too!
What was that # your friend said u couldn't run on stock stuff? 12's, right? You've done that, & then some. You're gonna need exh anyway shortly.
What all did u change this time? If u didn't already, remove that hitch & plates!
Old Aug 12, 2010 | 05:29 PM
dragpac's Avatar
good run,I can't imagine a track in Alaska.how many months do they run?
Old Aug 12, 2010 | 05:48 PM
Dezert1500's Avatar
Stickier tires aren't going to do it. You'd need a high 1.5x on your current setup and I don't think that's possible.
Free up that exhaust and bigger injectors. Combined that would only be $500 and I could see 11's then. Exhaust is choking it up top especially in 3rd. You should run a better 1/4 with that E/T. Definetly not saying it's bad thoguh
Nice job btw.
Old Aug 12, 2010 | 06:09 PM
pittman's Avatar
Nice job btw.
I agree that exhaust is needed
Old Aug 12, 2010 | 06:13 PM
fastnblu's Avatar
Nice job btw.
Understand I'm not trying to but... Exh. & bigger injectors for only $500? That must be a real budget exhaust. Cause a good set of headers or a nice catback, could take that out w/. 1 fell swoop. Headers itself or catback by itself I meant. At least in stainless.
Ask me how I know.
