TIME SLIP DATABASE
new best 1/8 time tonight- bitter/sweet
Old Jun 29, 2014 | 10:57 PM
TXsilverado's Avatar
Default new best 1/8 time tonight- bitter/sweet
I met up with KBracing and GMCTRK at the local 1/8 tonight. drove in and dropped the tire pressure to 17psi and shot the **** with them for 20-30 minutes.
pass 1:
1.47 60'
6.85 1/8
100mph
I was excited about the 60' time, but it was supposed to be my baseline pass before giving it a little more power (atleast I hoped to give it more power)
I lightly touched the rev limiter on the 2/3 shift so I dug into the transmission table to get it fixed and found that I'm only shifting 6,800 rpm and this combo should hit a sweet spot around 7,200 rpm or so. I got even more excited! bumped the shifts to 6200, rev limiter at 7,500 rpm. I also went ahead and gave it 2* more timing across the board as I am still on my baseline tune that I first started the truck up on (hense the 6800 shift point that I didn't know about)
in the burn box I felt the motor missing. never done that. it **** all over itself and I aborted the pass. didn't even look at the slip. thinking it had to do something with my changes I backed everything back but kept the shift point at 7100. same ****, different pass. my ignition box is only seeing 12.7-13.2ish with the truck running. it's never done this **** before but it has me pissed. I was ready to get a good pass in
oh well, a new best without changing **** and finally dipped into the 1.4 range on drag radials. not bad for the 3rd trip to the track.
Old Jun 30, 2014 | 05:36 AM
JoeyGC5's Avatar
Good with the bad, but at least it was a semi-successful outing.
Old Jun 30, 2014 | 08:29 AM
pittman's Avatar
Damn strong sixty foot. Truck is bad *** !!!
Old Jun 30, 2014 | 08:58 AM
heavychevy01's Avatar
awesome 60'! 1.4xxs are fun! good luck with figuring out the issues.
Old Jun 30, 2014 | 09:12 AM
i'm hoping it's a battery or alternator. the ignition box is reading low voltage. worst case is i have to send the ignition box for an inspection/rebuild. i'm hoping the 60' gets even better once i grab onto the trans brake.
Old Jul 1, 2014 | 04:38 AM
TIM Z's Avatar
11 sec. Truck Mod
Wow man that truck is movin and looks like it's not done , congrats .
I've been there , ready to make a pass and stuff just isn't right , that sucks , but you'll bounce back once ya get the bugs worked out .
Any vid from that night ? I'd like to hear that LS singing around 7k
Old Jul 1, 2014 | 12:03 PM
nobody caught the first pass. hanging the front tires in the air on drag radials is a feeling I never thought I would get.
Old Jul 1, 2014 | 08:05 PM
custm2500's Avatar
Ph.D. in HUBRIS
That is sweet. Too bad no video.
Old Jul 1, 2014 | 08:14 PM
TIM Z's Avatar
11 sec. Truck Mod
Like your first ******* huh ?
pittman
Jan 19, 2016 07:06 AM
TAPyvehc93
Aug 21, 2015 12:50 AM
lycominghunter
Aug 15, 2015 12:26 PM
SloSVO
Aug 11, 2015 07:33 PM
fcompean
Jul 15, 2015 09:55 PM
