TIME SLIP DATABASE
70mm Z71 Stage II -1/8 mile results
Old Jun 12, 2013 | 10:50 PM
Choda's Avatar
Thumbs up 70mm Z71 Stage II -1/8 mile results
after this
https://www.performancetrucks.net/fo...esults-518656/
I ran up to the local 1/8 to see what it'll run.
60' = 1.9
1/8 = 8.60 @ 81mph
I'm holding 8 psi brake boosting but it's unloading the suspension and spinning/jumping the tires. The front end feels like the famous lifted truck death wobble lol. Wondering if I should even bother w caltracs or just strap the front down. I need to do more research first.
Once I can get the launch settled down and some 1.8s, I'll be very happy and dip into the 8.50s which might pull off a 12.9.
Made one pass w cutout close at 8psi = 8.8 at 77mph. The made four back to back passes w the cutout open at 10psi and all were 1.9s, 8.6 @ 80 mph
Special thanks for Mike at New Era Performance. Rick from Trick Performance and all u guys on here (specially the guys I txt all day w lol).
Old Jun 13, 2013 | 07:40 AM
custm2500's Avatar
Ph.D. in HUBRIS
Good potential for a 12 sec truck as it sits!
Unloading is generally going to helped more by shocks or controlling the front end. Caltracs are generally for wheel hop.
Old Jun 13, 2013 | 07:52 AM
Chevy_King1500's Avatar
good results!! I guessing this was in 4wd? this gives me some hope for my truck, i just need some traction.
so I would guess you're around 460rwhp, we have the same mph and you're a lil heavier
cam swap would do wonders
Old Jun 13, 2013 | 07:54 AM
ZO6Ted's Avatar
I got a 1.69 by just dropping the front all the way for the track by loosening the torsion bar tension. Bone stock suspension on 275x55x20's. Do the straps before anything else!!! Check out Stock 48.
Old Jun 13, 2013 | 07:55 AM
ZO6Ted's Avatar
BTW congrats! Nice time.
Old Jun 13, 2013 | 10:10 AM
fortplainman's Avatar
kinda interested to see what kinda suspension mods you have in mind to help launching. want wait to see some 1/4 mile times from empire.
Old Jun 13, 2013 | 01:42 PM
nonnieselman's Avatar
All you need is to just strap down the front end and your good to go.. you want a 4wd to just leave with no weight transfer or anything. just go.
Old Jun 13, 2013 | 01:56 PM
Byrdman11's Avatar
I see 12's in the future.
Old Jun 13, 2013 | 06:54 PM
JC03SS's Avatar
Almost the same time I run. 8.65 and I pull 1.86ish 60ft
Old Jun 23, 2013 | 03:17 PM
fastjweb's Avatar
I ran a 8.38 at 84mph in my crew cab, and that was a 12.8s at 107, just so you know.
