TIME SLIP DATABASE
315/60/15 M/T on 15x10 w/6.5BS, Is Bogart the only Option?
Old Nov 25, 2011 | 10:38 PM
300zxls1's Avatar
11 Second Club
Default 315/60/15 M/T on 15x10 w/6.5BS, Is Bogart the only Option?
I am looking to put together a rear tire/wheel setup to use on my RST and I-SS. I already have a set of M/T 315/60/15 drag radials. But I am in need of a set of 15x10 6.5"BS 6x5 1/2" rims that will clear the 13.25" O/D drums on the trucks. Seems like Bogart is the only option available. Anyone know of a off the shelf wheel that will work.
Old Nov 25, 2011 | 11:08 PM
tarinitup's Avatar
9 Second Truck Club
If you have drums it's easy. With disk 6.5 bs is hard to fit without custom wheel.
Old Nov 25, 2011 | 11:11 PM
lsxnation's Avatar
Banned
i don't think there a stock wheel, with that much BS, besides custom wheels.
Old Nov 25, 2011 | 11:43 PM
slowlsx's Avatar
Bogart is your only option really. How much power u running to run so big of a tire
Old Nov 26, 2011 | 08:45 AM
300zxls1's Avatar
11 Second Club
The RST has a built 346 with Warhawk Heads Pro-Flo intake Diamond pistons, eagle rods, 234 231 .595 cam. Finishing up the turbo setup now most likey it will be a TC78 @15psi. Should be good for 700rwhp.
The I-SS has a 383 and a 2.3L Whipple w/A2WIC setup in the works. Should be around 550-600rwhp.
Old Nov 26, 2011 | 09:45 AM
Phantom's Avatar
11 Second Club
That or convert to 5 lug
Old Nov 26, 2011 | 01:54 PM
300zxls1's Avatar
11 Second Club
Ya most likely I will just go with some Bogarts.
Old Nov 26, 2011 | 04:01 PM
JankesGTO's Avatar
Just went down this road.. Go Bogart. I think you may need more than a 6.5 bs with the 315 depending on if you have a drop on the truck.
Old Nov 26, 2011 | 06:04 PM
300zxls1's Avatar
11 Second Club
What size tire and backspacing are you running? The I-SS is at stock 2wd height right now. I know the I-SS sits a little lower than a regular SS also. But I wont be lowering the I-SS.
The RST pickup I have is the stock height from Regency which was 1.3/3. I wont be lowering it any farther either.
Old Nov 26, 2011 | 06:10 PM
Jake99's Avatar
I couldnt find anything eaither when I was looking, I ended up just doing a little grinding and running a 15x8 wheel with that same tire. It ended up working fairly good I just drop the air psi to 15 when I race and it still puts down a good tire patch.
thompson
Dec 27, 2017 06:48 AM
121
Jan 18, 2016 06:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
whitelazer
Sep 22, 2015 09:38 PM
