Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
Couple of Hemi questions
Old Mar 13, 2006 | 09:35 PM
Camo Hemi 4x4's Avatar
Dont know how much $$$ but I am working in miss. and haul a 20ft dump trailer some one told me about a wire (tcm toruqe control module)you can undo in the computer that controls the toruqe does antone know about that
Old Mar 13, 2006 | 09:57 PM
MrDestinE's Avatar
It is only for 03s as they have the separate engine and tranny PCMs... but the Superchips does the same thing with less worry about warranty issues.... probably the best bang for the buck! If you do exhaust look at those people who have done exhausts and bettered their times as a lot exhausts can cost you power.. a lotta cash for no gains.. If you change cams I recommend the blower cam from KRC as it will produce better low end torque than some of the others... A good COLD air CAI will do wonders but do not get one that takes in air from under the hood ( most all of them ) I built my own out of 4 inch pvc... good for 3 tenths at the track....
There are a lot of good things out there but just as many that will be a waste of cash so do lots of research!
TJ
Old Mar 13, 2006 | 10:32 PM
eabigrick's Avatar
a programer would be my first add on in your application. then i would look into a cai and exhuast, but like mrdestine said, be careful with your exhuast choice because if you open it up to much you will loose power. i have a 50 series 3 chamber with the stock tail pipe out the side with a 4" manaflow tip and it worked and sounded great before i done the headers, now the sound is unbelievable, but back to the subject on hand. the comp cams xfi260 would be another good choice for you. and if i pulled alot like you do i would for sure changes the gears. just do your research and remember you get what you pay for.
Old Mar 14, 2006 | 02:36 PM
thank alot for your advise
Old Mar 14, 2006 | 03:20 PM
ColtSteele's Avatar
YOu can get a new Ram with a lsd but I bought a peg leg and put a powertrax no slip and 4:56 gears. That, along with a highr stall tc made my truck drive GREAT!
lsxperformance
Apr 20, 2016 12:17 AM
Noah Burns
Sep 7, 2015 05:50 PM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Rwilliams85
Jul 14, 2015 04:36 PM
