E-Fans in my 99 OBS EscaHoe 7 other coolin ?'s
Old May 6, 2009 | 11:47 PM
foreverfalcon40's Avatar
Default E-Fans in my 99 OBS EscaHoe 7 other coolin ?'s
I've done some researching:
That not to do a toggle switch! Too many horror stories! SO I'm getting the Harness so it turns on and off like it STOCK!
What I don't know...WHICH ONE'S SHOULD I USE? Some people have E-Fans from LS-1 or Taurus/Sable...Flex-Lite
Also, some members have them stacked! Four total...think that is over kill?
Other Cooling Questions: Came Across someone saying something about "HD" Radiator. Does that mean Heavy Duty? What about a 160 T-Stat? Some say its good, some says its not b/c some yrs engines are made to run efficiently hotter.
I'm getting a Black Bear Tune in AUG. My Budget is $500-$600 before tune and its costs.
My Plan of Mods to do before the Tune is: E-Fans, MSD Ignition, TB.
Good?
Old May 7, 2009 | 01:04 PM
S/C Z71's Avatar
Banned
Perma-Cool makes a sweet unit. I believe the 98-99 OBS black boxes can control e-fans so you might not even need to get a harness.
Old May 13, 2009 | 05:44 PM
Any info on T-stats?
Old May 13, 2009 | 05:51 PM
03tahoe22's Avatar
Do you have a 5.7L?
Old May 15, 2009 | 11:09 AM
S/C Z71's Avatar
Banned
Go with a 180 if you're N/A and a 160 if you're boosted.
Old May 20, 2009 | 12:43 PM
Any brand recomendations on a 180-t stat? There's so many options.
Thanks,
Jason.
Also do you recomend installing the t-stat and e-fans together or can I just install either or first.
Old May 24, 2009 | 11:49 AM
JFOLM's Avatar
well i am about to install a 34inch radiator (ck2500's ck3500's use them) and the 05+ stock efans. setups look really nice with this set up and people say with that big radiator it stays cool ALL the time. JET makes a temp switch that will turn the fans on/off.
just some food for thought.
Old May 24, 2009 | 11:13 PM
I'm going to go with Black Bear, they make a harness so E-Fans will work like OEM fans.
Please take pics! Will the Radiator bolt up? What year and make is your vehicle?
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
lxcoupe
Sep 23, 2015 12:11 AM
lxcoupe
Sep 21, 2015 11:53 AM
350SS
Jul 11, 2015 12:34 PM
