88 TBI problems. Please help.
Old Sep 15, 2014 | 04:31 PM
Fastcount03's Avatar
Default 88 TBI problems. Please help.
A friend of mine has an 88 TBI 350 and it will crank and injectors spray, but gets no spark. He has replaced ignition control module, electronic spark control module, pickup coil, cap and rotor, and coil. He has power from the coil to the cap but no spark from the cap. I'm not too knowledgeable on these and I have no wiring diagrams. Any suggestions, and/or wiring schematics, or pics would be of great help. I suggested replacing the whole distributor, but no sense in throwing parts at it until we figure out what is bad. Thanks in advance.
Old Sep 16, 2014 | 12:08 PM
boostdsierra's Avatar
I had a very similar problem on my 89' K5 but ended up swapping to HEI before figuring it out.
Do you have the option to swap out the distributor, maybe off a similar running vehicle to see if you have the same issue?
Old Sep 17, 2014 | 07:35 PM
Jason Z69's Avatar
Check all the grounds. Especially motor grounds.
Old Sep 17, 2014 | 09:15 PM
ChevyThunder17's Avatar
That makes a lot of sense, as most people check for 12 volts and not whether the ground is well, grounded.
Old Sep 20, 2014 | 12:21 PM
Yes we checked all continuity and voltage. It ended up being the distributor. Thanks for the help. I'm not too keen on distributors. I still don't understand why the old one wasn't working after we replaced everything on it, but at least we got it figured out. Appreciate it guys.
Angry Silverado
Oct 21, 2015 07:07 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
Wrecker 426
Sep 30, 2015 09:39 PM
MOBBN
Sep 22, 2015 08:07 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
