doing brakes anyone heard of these things
Old Jul 10, 2010 | 04:17 PM
justincredible5's Avatar
Default doing brakes anyone heard of these things
http://cgi.ebay.ca/01-04-GMC-SIERRA-...item3cab5ea3a5
cruisin aroung ebay found these wondering if i should pull the trigger and take a chance anyone got any feedback
Old Jul 10, 2010 | 04:19 PM
http://cgi.ebay.ca/GMC-Sierra-1500-H...item335e291f7b or these ones
Old Jul 10, 2010 | 07:14 PM
xx_ED_xx's Avatar
you are in the 8 lug forum asking about 6 lug brakes?
Old Jul 11, 2010 | 07:59 AM
the first one states that they are for a 1500hd heavy duty models only which is an 8 lug and the second one states 8 lug vehicles only
Old Jul 11, 2010 | 03:14 PM
bighoss77's Avatar
drilled/slotted rotors on stock sized rotors is a bad idea. your loosing surface area. with a larger brake kit, drilled/slotted rotors work well.
Old Jul 11, 2010 | 07:22 PM
AKAFRED's Avatar
i got the cheapo drilled rotors off ebay they seemed to work fine.
Old Jul 14, 2010 | 06:55 PM
bbc4542001's Avatar
drilled and slotteds work fine. They stop better due to degassing and reduce stopping distance they are worth it if you dont have the 3g per set and tires and wheels for wilwood big brakes
Old Jul 14, 2010 | 08:42 PM
Modern brakes on consumer vehicles do not degas. Period. 10-15 years ago, sure, alot did. All drilling and slotting does is remove important iron that helps dissipate heat to help brake better. Quality pads with quality blank rotors (no holes or slots) is the best solution for a modern day car and truck. I've always stuck with OEM for a good balance of low noise, low dust and decent stopping power.
Old Jul 16, 2010 | 01:14 AM
xx_ED_xx's Avatar
Yup my bad i saw 1500 and not the HD and the pic didnt help either with 5 lug
Oobray
Jun 13, 2022 03:38 AM
Jake99
Aug 8, 2015 07:56 AM
76k10chase
Aug 4, 2015 03:28 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
mrgrim
Jul 8, 2015 08:12 AM
