8.1L Timing - How low is low?
Old Apr 20, 2013 | 07:11 PM
406jeep's Avatar
Default 8.1L Timing - How low is low?
I have seen several posts where folks say the 8.1's like low timing?
How low is low? How far should I go? Motor breaks up in the 2500 to 2800 rpm range. HPTuner scanner shows I am still getting some knock retard in this range. I started with the stock curve from a 2003 suburban and have been adding fuel and taking out timing. AFR's are pretty good, so I am assuming it must be timing.
I have been taking out 1 to 2 degrees at a time. Should I be pulling timing in 5 and 10's instead?
For HPTuner guys, tune file and log file attached. (Also any other bonehead mistakes you find in the tune file let me know)
File Type: hpt
File Type: hpl
Old Apr 29, 2013 | 05:28 PM
xx_ED_xx's Avatar
When i was running my 8.1 on the ls1 msd box. I had 28 degrees total and like only 10 degrees total advance otherwise it would ping
Old Apr 30, 2013 | 06:35 AM
406jeep's Avatar
I think I am narrowing down my problems. I may have several small issues rolling up into a larger one. Bank 2 is running leaner that Bank 1. I have dual widebands on it as well as the factory sensors both are showing Bank 2 as lean. Possible bad injector or bad plug wire and/or coil
I starting with the cheapest fix first. I replaced the plug wires. That helped some, the difference between Bank 1 and Bank 2 is slightly less. I was finally able to make a WOT run, and maxed out the injectors to 100% duty cycle.
New 42# injectors will be here today. I will swap them out and see what happens next.
Just to be sure I understand you correctly, your base timing curve had a peak of 28 degrees and peak of 10 degrees of MAP advance.
Thanks
Old Apr 30, 2013 | 07:26 AM
xx_ED_xx's Avatar
Put a real fuel pump in it.
I was having issues with mine and after installing a fuel pump that had some volume it fixed a bunch of my issues
Old Apr 30, 2013 | 09:25 AM
406jeep's Avatar
Fuel pump was my first guess. I added a fuel pressure sensor to the data logger and it is holding 50 to 51 psi at WOT. Fuel pump is a walbro 255. If pump becomes my next weak link I will probably go to dual pumps.
Old Apr 30, 2013 | 10:25 AM
TieRod's Avatar
Is that Raylar's 102 torque cam your running?
Old Apr 30, 2013 | 11:29 AM
xx_ED_xx's Avatar
ah yes your jeep is red right?
Old Apr 30, 2013 | 12:16 PM
406jeep's Avatar
The paperwork says BP202, but I think that is the 102.
I had a red/yellow CJ3b with a 406 in it years ago. But you are probably thinking about another CJ with 8.1L from Alabama. I have seen photos and videos of it.
This is the current project
Old Apr 30, 2013 | 12:20 PM
xx_ED_xx's Avatar
ha ha thats kick ***, so 2 jeeps with 8.1's freaking amazing
Old Apr 30, 2013 | 01:07 PM
02_2500avalanche's Avatar
whats the lobe separation on that cam? jeep is badass
