quick tech question about PCV
i think i already know the answer to this but i'll go ahead and ask.
I'm running a vic jr intake with a ls6 valley cover. the pcv from the valley cover is 3/8, but i cant find anywhere on the intake to plug in to pull a little vacuum on the crank case.
in the very back of the intake there is a 3/8 hole threaded for the brake booster. do you guys think it owuld hurt to put a 3/8 tee back there and run the booster from one side, then the PCV vacuum on the other side? the only alternative that i see other than going this route is to tap a new 3/8 hole into the intake somewhere.
does the crank case vent pull enough air to effect the brake performance if they are both drawing for
to make sure i understand you correctly...you're saying a 3/8 barbed tee spliced into the booster line, then run the PCV to the 3rd side???
can anyone verify what size the booster line is? i was assuming it was 3/8 but i have my doubts now. it's on a 96 s10.
Three6GMC
Aug 28, 2015 07:56 AM
