wideband bung
Old Jul 25, 2005 | 02:38 PM
wkdivr's Avatar
Default wideband bung
I'm going to install a wideband bung in my stock y pipe to facilitate future wideband tuning. Where should the bung be placed. I know it should be in either the 2 o'clock or 10 o'clock position, but where on the y pipe is the best place? After both cats, right before the joint at the cat-back, or some other place?
Old Jul 25, 2005 | 09:28 PM
wkdivr's Avatar
tttttt
Old Jul 26, 2005 | 12:37 AM
kbracing96's Avatar
I don't think it really maters to much. I have a STS and I put mine clear back there, so it was after the turbo and it seem to read well and is very responsive. Every thing I have heard said it needed to be after the turbo, but your supercharged, so I don't thing it's all the critical where you put it. You will get a better average of the motor if it is sampling from both pipes, but unless you have a problem with one side of the motor, then that won't mater anyway.
Old Jul 26, 2005 | 01:26 AM
BLOWN 364's Avatar
Right before the cat back joint on the y pipe will be fine.
10 or 2 0'clock is right as long as you have 4" or more of clearance from bung for the sensor.
Old Jul 26, 2005 | 06:00 AM
wkdivr's Avatar
That's what I needed! Thanks!
Old Jul 26, 2005 | 08:30 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What about if you have true duals. Im thinking about getting one from a gp on tech and mounting it at the y just isnt an option for me.
Old Jul 26, 2005 | 08:36 AM
quicksilverado's Avatar
I removed the rear O2 on the drivers side and replaced it with the wideband O2.
Old Jul 26, 2005 | 10:44 AM
BigKID's Avatar
If at all possible, put it before the cat as it will have a more acurate reading there than after. When I had true duals, I had the sensor on the driver side just after my header collector. Now with the new single setup, I have it just after my Y-junction and it reads about the same as it did running on one bank.
Old Jul 26, 2005 | 01:37 PM
1slow01Z71's Avatar
I dont have cats so can I mount it basically wherever I want or just off the collector?
Old Jul 26, 2005 | 08:09 PM
Lord Aries's Avatar
What kind of sensor are you guys using? And where are you buying them from?
Thanks
