Valet Mode
Old Oct 17, 2009 | 12:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Default Valet Mode
In the speedo tab of HPT I lowered all speed limiters to 45mph.
Speedo--->Speed limiter
I also set Rev limit off to 3000rpm on at 2999 rpm.
Engine--->fuel controll--->fuel cutoff--->cutoff rpm vs. gear normal.
I took it for a drive and it works great. Try going into boost and it shuts down, take it over 45 and it gently cuts off. Dropped the truck at the painters and now I can be assured nobody will be taking joy rides
Old Oct 17, 2009 | 12:41 PM
KLUG'S SS's Avatar
FormerVendor
Good thinking! I need to be setting up my truck like that before my wife drives it.
Old Oct 17, 2009 | 12:50 PM
trever1t's Avatar
yeah, I had been thinking about this for a while, wish I could set it up with a key switch, hard-wired so to speak but that's well beyond my understanding.
Old Oct 17, 2009 | 12:56 PM
53RUSSELL's Avatar
Bill can't you just put a switch on dash for the Valet Mode and then wire it in to pcm?
I know EFILive will let you do that. So when drop truck off at Valet i turn that switch on and it Valet mode.
Old Oct 17, 2009 | 12:58 PM
JonCR96Z's Avatar
With the beta you can control throttle to pedal relation. You could make it feel no responsive and/or have the throttle only open half way at max pedal.
Old Oct 17, 2009 | 01:05 PM
trever1t's Avatar
Yeah I had heard of that and I think it's possible to have something similar with HPT I just don't know how to rig it.
With HPT beta? there's an update out? details on this please?
Old Oct 17, 2009 | 01:12 PM
JonCR96Z's Avatar
Email support and ask them for the Beta. Once received they will put a link on your customer login page.
Beta has a few more tables for the older PCMs and a ton more for the newer ones, but it is still a beta which means it could have potentially more glitches than a full public release.
HPT warns heavily about messing with the ETC values, but I believe that EFIlive has had the options for a while and I haven't heard of any bad things happening.
With that said, you should still read up on the beta and check out the EFIlive forums to make sure I'm correct on what I said before you damage anything.
Old Oct 17, 2009 | 03:54 PM
hirdlej's Avatar
Why would messing with the ETC values be bad? Please explain what table you're referring to.
Old Oct 17, 2009 | 03:58 PM
KLUG'S SS's Avatar
FormerVendor
Yeah I have heard of a few pcm's being fried now after people were screwing with some settings under the Electronic Throttle tab in HPT. At this point I dont feel that the any of the changes under that tab are going to lead to any huge improvements in performance anyways but I was planning on doing some testing soon to find out.
Old Oct 17, 2009 | 04:06 PM
JonCR96Z's Avatar
Read the message at the bottom in the main window.
