Undecided on cam selection for street/tow SUV 5.3LH6
Old Sep 24, 2017 | 08:56 AM
  #31
thebrain's Avatar
yes cool sounding is more important than actuale HP gains this mite be a good place for mail order tune.Mail Order tuning for ALL 97/LS1 - UP ENGINE SWAPS
waiting on ECM advice
Old Sep 24, 2017 | 09:05 AM
  #32
thebrain's Avatar
I dont know if I need new valve guides
was planning to have heads resurfaced maybe new valve guides? what is done on a valve job?
my dod kit will have valve stem seals and head gaskets
Old Sep 24, 2017 | 09:23 AM
  #33
TXsilverado's Avatar
Originally Posted by thebrain
I choose this cam 212/218 .600"/.600" Truck Camshaft LSA 114
https://www.texas-speed.com/p-4925-t...-camshaft.aspx
that's a good proven cam. a little on the big side for a towing tasked 5.3...perfect for a 6.0 intended for towing only. if towing is still the goal, i would drop the LSA to 110 or 112 with 4* advanced in for a 106-108 ICL. a lower LSA will make it sound tougher too if that's what you're after...
in the end, i still think you want a blower, and just don't realize it. i understand the DOD delete, and milling the heads, but wasting money on a cam and valvetrain for more towing performance is throwing money in the toilet.
as for the valve guides, your stockers are probably fine. how many miles on the motor?
Old Sep 24, 2017 | 09:39 AM
  #34
thebrain's Avatar
152K
this vehicle has a set of worn out nittos so the previous owner must have thought this car was fast and drove it so, I've only driven on the long drivway
seams strong even on 7.
towing is it's primary use however when I get to the desitation I want to cruise around a little w/out trailer. read back a few pages I'm planning on a LY6 w/L92 heads plan to use this cam in both 5.3 then later in the LY6 build.
I choose LAS114 to not attract unwanted attension from Johnielaw
still waiting for tuning advice.
Old Sep 24, 2017 | 09:45 AM
  #35
at that mileage i wouldnt mess with valve guides unless you see an issue once you get it apart.
a few of our sponsors offer live tuning. check them out. if you're willing to purchase HPtuners, they can tune by e-mail and nail the tune down. or, you can buy a efi-live scanner for less $ and scan/upload tunes through e-mail as well. the 2nd option will not allow you to make your own changes...both of those options are better than a canned mail order tune.
where do you live?
Old Sep 24, 2017 | 09:49 AM
  #36
thebrain's Avatar
montgomery,Alabama I can take the wide band AME off the WS6
Old Sep 24, 2017 | 12:06 PM
  #37
RPMSpeed Tech's Avatar
Truck Sponsor
Originally Posted by smokinlmm
I think you'd be better off with the stock cam and go FI. The cams your looking at wont be good for future blower applications, the lsa is too low, the stock lsa is 114 which would be smoother than the 112 your looking into and make better power with FI...
The only reason to change to a wider lsa on a supercharger is to combat overlap. even on a 112 that cam has a good amt of negative overlap.
