tranny shifts way to hard into thrd
Old Sep 13, 2009 | 01:17 PM
searcey6.0's Avatar
Default tranny shifts way to hard into thrd
could this be a transmission module problem or more likely a mechanical problem it a 2002 4l80e mated to a 6.0l. has anyone else had this shifting problem? its only in the second to thrd shift.
Old Sep 19, 2009 | 08:33 AM
searcey6.0's Avatar
anyone? the shift gets harder the more i drive it. and its seems to be at about 3200
Old Sep 19, 2009 | 02:32 PM
chevyguy7802's Avatar
What are your mods? It is tuned?
Old Sep 19, 2009 | 03:38 PM
viciousknid's Avatar
Where's the Beef?
Is it tuned? this makes a difference.
If it's stock and doing it somethings wrong. If it's tuned and has been doing it since you tuned it then you just adjust the pressure.
Old Sep 19, 2009 | 08:49 PM
searcey6.0's Avatar
well i bought the truck from my dad who put a hypertech tune on it but he says it was doin it when he got it. should i try and mess with the tuner?
Old Sep 19, 2009 | 08:54 PM
01SilvyZ71's Avatar
custom tune yea.
get rid of that hypercrap junk
Old Sep 19, 2009 | 09:21 PM
searcey6.0's Avatar
if its not the tune what kinds of things could it be? i flushed the trans and put new fluid in it then drove from Ft. Worth to San Antone (about 360 miles) and it progressivly got worse. also it shifts very quickly to fourth after the second to third shift every now and then.
Old Sep 20, 2009 | 01:16 AM
Jeteys5.3's Avatar
no no no. You shouldn't flush your trans. Just drain and refill. Not saying thats it but that might be causing it. Flushing the trans can/will do more damage than good.
Old Sep 20, 2009 | 12:10 PM
jschrock's Avatar
Word only about 1 out of 5 trans flushes actually work. The other 80% do more harm than good. I would say get a tune and have the tuner soften up the 2-3 shift probably by 4-6%
Old Sep 20, 2009 | 12:33 PM
searcey6.0's Avatar
so what i should prolly do is take the programmer off and see if it still does it then i know if its mechanical or not. then i guess go to nelson? they are right here in san antonio where im stationed right now. anyone got any good words to say about them? or bad?
