stall not staying locked up
#31
That setup should probably pull around 12 mpg mixed.
Sounds like your tune is ****. And the converter not locking could definitely be due to false misfire from the cam. I set my low limit detect to 1500 rpm. That should take care of that issue.
#34
played with the misfire tables. i can keep the stall locked now but only when the truck has a load on it. either if i am accelerating or climbing a grade on the highway. the second i pull my foot out or start to go down hill it unlocks. what am i missing i dont see anything else i can play with to keep it locked up.
#35
Like mentioned, you need to understand what the minimum throttle release tables do and how they function. Read the descriptions carefully and see what you come up with. Post a screen shot of what yours look like and I'll nudge you in the right direction.
#36
#38
nailed it. i used the program and it didnt change those tables so i left them alone. i will install that this morning and see how it drives. i cant afford to blow up anything else right now so screwing up is not an option.
#39
#40
