stall not staying locked up
Old Apr 8, 2014 | 09:59 PM
  #21
cdub81's Avatar
Originally Posted by greasemykey
i zeroed out my shift time on both tables and i dont know if i am reading this table right but if i open my TCC apply and release speed it displayes vehicle speed the gear to lock up and the % the throttle is open to lock the converter correct? Yes vehicle speed is in the boxes. throttle % is top axis and column axis is gear
it looks that 2nd gear had no TCC lockup because its not set to engage at any throttle position until the truck is at 254mph. wouldnt it correct the issue if i reduced the speed of the 4th gear lock up?
You wouldn't want any 2nd gear lockup even at part throttle/city driving etc.
If you don't have a milti disc converter then you doin't want any WOT lockup which is why everything at 88% up is 255. The release tables should be at 100%, I've never messed with those tables so that's not your issue.
Here's a screenshot of the bluecat tool with my settings in it and then my trans tables. You can see I tweaked the lockup MPH compared to what the software says. IIRC it would unlock easy with light throttle when I first uploaded the starter settings, I tweaked from there. You'll just have to play with it, its the only way to really teach yourself.
Old Apr 8, 2014 | 11:20 PM
  #22
greasemykey's Avatar
thanks for all your help. i updated all the tables and saved it. i will upload it tomorrow and see how it does on the way to work. i have got to get the timing and fuel tables figured out soon. i ate through 26 gallons of fuel in 120 miles. a bit much if you ask me. shes running rich. figured i need the trans tuned first then toy with the rest as i learn more.
thanks for all your help. ill post up how it works out tomorrow.
Old Apr 9, 2014 | 12:01 AM
  #23
oakley6575's Avatar
Holy ****. What do the plugs look like.
Old Apr 9, 2014 | 01:35 AM
  #24
alot like this one. sorry couldnt help myself. ill pull them tomorrow and look.
Old Apr 9, 2014 | 01:40 AM
  #25
03sierraslt's Avatar
Why is it so rich? That's a bit beyond exccessive.
Old Apr 9, 2014 | 10:36 AM
  #26
its a stock tune. he turned off the MAF and thats about it. take a look at the tune i am running 57lb injectors.
Old Apr 9, 2014 | 02:28 PM
  #27
installed the tune this morning and same issue. wont stay locked. alot of my fuel issue is the fact that at 70 im turning 2800rpm or so.
Old Apr 9, 2014 | 02:41 PM
  #28
I am on mobile, can't see the tune.
Old Apr 9, 2014 | 03:20 PM
  #29
Ferocity02's Avatar
My MPG's took a **** also with the 80E and converter. Makes me wish I stuck with the T56.
Old Apr 9, 2014 | 04:14 PM
  #30
i didnt really care all that much about MPG but im about 5 to 6 MPG. i think that is a bit low. but i dont have much to compare it to. either way she still wont stay locked up. should i try and move up my misfire tables?
