Rough idle
Old Dec 28, 2007 | 12:42 PM
53RUSSELL's Avatar
Default Rough idle
This all started when the weather got cold. When the truck start up it idles really rough and the whole truck rocks like it has a cam. To me a sound like it has too much fuel and sounds like missing on the exhaust. When it idles why is the spark all over the place? Here is the log file.
Old Dec 28, 2007 | 04:41 PM
DrX's Avatar
DrX
Can you post your tune?
Old Dec 28, 2007 | 05:39 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Sounds like it's a case of denser air, and fuel feed is surging trying to adjust. Slight AF change in tune should take care of that.
Old Dec 28, 2007 | 07:05 PM
53RUSSELL's Avatar
take a look and let me know.
Old Dec 28, 2007 | 10:14 PM
53RUSSELL's Avatar
Well i was looking at my old log files and my log new file and found that lfts are realy high 02 are runing lean. So think i have leak some where.
Old Dec 29, 2007 | 12:20 AM
jakebdb56's Avatar
I sometimes have this problem, in a way. I just give it a few revvs if it does it and that usually fixes it. If it doesn't, I just make sure I get the motor warm quick.
Old Dec 31, 2007 | 08:53 AM
white lightning SS's Avatar
Intake gaskets are a big problem on these trucks, they leak vacuum at the bottom edge and the problem shows up as soon as it gets colder out. I would check those out especially if you ltft are running lean.
Old Dec 31, 2007 | 11:20 AM
Mort's Avatar
Maybe the cold temps are opening up a bit of an exhaust leak. Might be worth checking.
Old Dec 31, 2007 | 03:45 PM
53RUSSELL's Avatar
Well I got the problem fix. I cleaned the maf, intake tube,filter, throttle body, put a new fuel pressure regulator, and found a lose vacuum hose. The lfts look a lot better than the last log.
Old Dec 31, 2007 | 06:48 PM
03sierraslt's Avatar
Just a tuning FYI- It doesnt have to be very lean to affect idle however it can be pretty damn rich without a noticable change in idle. For referance I have seen mine idle just fine at 11.0 afr however on the lean side I start noticing a change in idle at about 15.9 or so AFR.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Pimpinpete
Sep 8, 2015 07:39 PM
