Riddle me this... Strange IDC jump
Old Aug 27, 2012 | 12:13 AM
nonnieselman's Avatar
Default Riddle me this... Strange IDC jump
Ok so it just dawned on me.*
First night i put the turbo on i was out checkin the tune and the IDC was 93% at 5700rpms, 11.2AFR, 5.2psi.*
I got my methanol hooked up and AFR was in the 10.3ish range. I leaned it out so its roughly 11.0.*
Now my IDC is 120%. But nothing changed except i leaned the boost VE out so the AFR would be close to targeted.*
Why would it change so much when i was expecting it to go down. I did add about 4-5* timing. Maybe thats it?*
Then at 5850-6000 it goes from 11.0-11.2 to 12.4s, so i added fuel on the boost VE table. It still had a lean spike so i set it to shift at 5200 since the AFR looked good there.*
What gives?
Old Aug 27, 2012 | 03:55 AM
AndysC3's Avatar
Hows fuel pressure?
Old Aug 27, 2012 | 08:09 AM
I gotta check.
Old Aug 27, 2012 | 09:26 AM
Atomic's Avatar
I have a gauge for that
IDC is based on the IFR table and the pulsewidth, not much else. At WOT a weak pump will show as lean, not higher IDC. As far as your question, im not really sure...
Old Aug 27, 2012 | 09:32 AM
03sierraslt's Avatar
What does your IAT adder table look like? Think that's what it's called...
Old Aug 27, 2012 | 10:05 AM
IAT fuel or Timing?
if i can find my jumpdrive, ill upload the tune.
Old Aug 27, 2012 | 10:12 AM
Fuel
You use hpt or efi?
Old Aug 27, 2012 | 10:29 AM
ill have to look..
EFI Live
Old Aug 27, 2012 | 10:50 AM
Gadgetized's Avatar
This has me stumped, in for the results.
If you unhook the meth, and put your fuel back, the IDC goes down?
