Reduced Engine Power, U0107
Old Nov 4, 2011 | 01:56 PM
blackcash's Avatar
Default Reduced Engine Power, U0107
Code I'm getting is U0107, Lost Communication with TAC. When I first did the swap it was great. Little while later it'd go into REP after going WOT for a while. Other day it turned a 2 hour trip into a 5 hour trip cuz it would kick into REP every 1/4 mile or so.
My connections are good, although when I did the swap I extended the pedal to TAC harness to go through the throttle cable hole instead of through the firewall. Added maybe 6" of 14 guage wire. But I imagine if it was an ohms and resistance issue there, it would have popped it's head up immediately.
Also using an 03 TAC on a 05 PCM calibration. Thought that may be an issue.
Or did my junkyard TAC bite the bullet?
Old Nov 5, 2011 | 10:28 AM
bentrek's Avatar
i'm getting the same code, but with a few other symptoms....here's my thread
https://www.performancetrucks.net/fo...-power-491526/
maybe a common issue, maybe not.
here's another interesting one from awhile back...they also extended thier wires to the throttle body
https://www.performancetrucks.net/fo...-power-364386/
Old Nov 5, 2011 | 10:36 AM
bentrek's Avatar
OOPS, my code description is different than yours.....states "lost comm with throttle control module" is that different than the TAC?
Old Nov 5, 2011 | 07:50 PM
blackcash's Avatar
That is the TAC. Mine said the same thing I just typed it shorter
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
steves86ta
Jul 28, 2015 10:21 AM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
