Re-tune time
Old Jul 21, 2006 | 05:25 PM
jadaven's Avatar
Default Re-tune time
Anyone got any ideas I'm missing right now. I like to hear some perspective.
Before I send it in to W4M.
Thanks
2. What you want done or what you want out of the tune:
As much performance out of octane 87 as possible.
Remove 50% Torque management
Optimize shift points,
firm shift points,
Raise WOT shift points to 6100RPM,
Remove top speed limiter
Delete A.I.R & EGR
Fix Speedo; I have larger tires so they make it read 8mph lower than actual speed being traveled.
Remove Abuse mode
Delete Rear O2s
Delete code PO154 (causing me to get a SES light)
Tow/haul *** button (I’ve heard a little about this from some guys)
3. I have: K&N 77 series intake. Corvette servo. A Flowmaster one chamber dumped at the axle. Taylor 8mm plug wires. Hamm Mid-length Headers. TB bypass.
4. 265-75-R16 (Total Tire Height 30.25)
5. Gear ratio – stock 3:73
6. 87
Old Jul 21, 2006 | 08:24 PM
FastCrewCab4x4's Avatar
Looks Like you got about everything covered, when you want somthing else changed or just dialed in, send it back. they are very fast about re-tune turn around. I'm very happy with mine & Them. Enjoy
Old Jul 22, 2006 | 02:35 AM
dc_justin's Avatar
Hello Dave
P0154 is "O2S Circuit Insufficient Activity Bank 2 Sensor 1".
You should not ask him to disable that. That's an indicator that you have a real problem related to that O2 sensor. You're probably running around in Open Loop right now on the passenger bank because of that.
Old Jul 22, 2006 | 04:01 PM
jadaven's Avatar
so how do you fix that. I just replaced the b4 cat O2.
Old Jul 22, 2006 | 04:50 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Also I would ask for a 91 octane (or your highest available gas) tune. The tune will be better as far as performance AND you'll get better economy too! The difference on a full tank is about $5.25 so why skimp?
Not only that but you'll get the additives in the premium!
Old Jul 22, 2006 | 05:07 PM
Blue5.3's Avatar
Old Jul 22, 2006 | 08:41 PM
AND, you'll get more milage from a tank of premium than you will with a tank of reg. and if you figure it in cents per mile, premium is cheaper to run. try it
Old Jul 23, 2006 | 12:55 AM
ltn's Avatar
ltn
hey i got a retune and got the 91 tune, but if i ever have to send it in again do u think they will let me keep this one and send me another. The reason is that since i have the e fans on my truck and a nelson harness. There would be no way for me to run them if i sent my pcm in. just wondering if anyone has done this before.
thunder550
Oct 8, 2015 04:53 PM
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
