Which power inverter do you use.
Old Jan 6, 2012 | 11:36 AM
AndysC3's Avatar
Default Which power inverter do you use.
I'm wanting to install a power inverter in my truck. It will be a permanent install with power connected to the battery. Some of the things that I would use it for: charging my lap top, camera battery and a tire inflator. Thinking about something in the 600w range.
Old Jan 6, 2012 | 05:35 PM
Dewey's Avatar
TrippLite PV700HF or Duracell is what I'd recommend
Old Jan 6, 2012 | 08:31 PM
Suburbazine's Avatar
Are you looking to run any motors or audio equipment? If so, you need a Pure Sine inverter. Squarewave inverters, while cheaper, are hard on some motors and make a lot of line noise.
I run a Whister 1200w modified sine inverter. It generally has enough pep to run whatever I need it to.
Old Jan 7, 2012 | 01:00 AM
AndysC3's Avatar
no motors. mainly my laptop and camera batteries. Needs to be small enough to put under the center console.
Old Jan 12, 2012 | 01:49 PM
AndysC3's Avatar
where do you the inverter mounted? Im thinking about inside the center console under the dash.
Old Jan 12, 2012 | 04:58 PM
nonnieselman's Avatar
I mounted a Cobra 750W under my back seat, hooked to a relay under the hood and a switch in my center console to control it.
Ive had it for about 6 years and still goin strong.
It has a USB connection on it to so you can charge stuff there also.
Old Jan 12, 2012 | 05:55 PM
AndysC3's Avatar
I just ordered the Whister-Pro 1200w power inverter. I have some left over 4 gauge wire from my audio install in my jeep. Going to mount it under the rear seat. Thanks for all the help.
Old Jan 12, 2012 | 09:13 PM
You gonna run it hot all the time? I had problems with mine running my battery down if i didnt turn off. Thats when i was traveling and didnt drive it for 5-15 days at a time tho.
Just throwing that out there.
Old Jan 13, 2012 | 03:10 PM
AndysC3's Avatar
It has a on/off switch. If I run into issues I'll add a relay.
Old Jan 18, 2012 | 01:52 AM
AndysC3's Avatar
I got the inverter in. I did a quick test using some jumper cables and it works pretty good. What size wire should I run. I have a bunch of 4ga wire that I could use. or should I get some 2 gauge wire?
