pcm questions
Old Jan 3, 2007 | 08:24 AM
joehawkz71's Avatar
Originally Posted by RandomHero
i would get an 02 pcm. The 99-00 pcm's are notorious for having false knock,when I got EFI live.
yes..when i did all my mods to my truck i was getting 6-8* of knock....then i bought an 02 pcm and i have no knock now! also installing the 02 pcm is easy but getting the truck to run on the new computer is a pain ibn the ***...you have to do a secirity learn! otherwise you the will just fire once and thats it!!!
Old Jan 3, 2007 | 10:30 AM
logan214's Avatar
I have an 06 denali and Nelson gave me an 04 PCM. Do you think that would make a difference? Not trying to change thread but kind of the same subject. I bought HPTuners last Thursday and concerned with the same questions. I still have my 06 PCM in box but had to do a security relearn for the 04 PCM when I had the kit installed.
Old Jan 3, 2007 | 10:37 AM
JERRY2500's Avatar
14 Second Truck Club
Go with the 02 PCM, It solved my false knock issue. Just make sure you get HPtuner for an 02 truck
Old Jan 3, 2007 | 10:55 AM
foff667's Avatar
LS1TECH Sponsor
The great thing about hptuners is you can also compare two different operating systems against each other to see any differences between them
Changing over tables from one to the other is just a couple of clicks away as well
Old Jan 3, 2007 | 08:59 PM
budhayes3's Avatar
PT's Slowest Truck
Swapping an 02 PCM into my 99 made a world of difference, both tuned and untuned. After my cam swap, I was getting 7.9* of KR every time I just opened the throttle with the 99 PCM, both with and without tuning...the 02 PCM solved that, even without tuning. Once the 02 PCM was tuned, it was awesome. From what info I've gathered, the 01-02 PCM's have a different OS and more parameters that can be adjusted. Another item that the 99's have that's different is the injectors...they flow less than 00 and up (something like 19 or 21 lb vs 24.7 lb).
Old Jan 3, 2007 | 09:23 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Why not just adjust your tune to desensitize the potential KR issues? I bought an '02 PCM b/c everyone expressed the opinion of false knock, and having no workaround. I got "knee-deep" into my tune, and have no issue with false KR. Depending on weather conditions, I maaaaaaaay see 1 degree or so, but that's about it. I've talked to pro tuners local to the BR area, and they agree that sure false KR seems to be an issue, but can be eliminated w/o having to buy an '02 PCM. Is this a load-o-crap, and am I seeing mirages with my logs?
Old Jan 4, 2007 | 02:30 PM
getchusum99's Avatar
ive been told the same thing, that you can eliminate the problems without getting rid of th 99 pcm. i currently have a F'd up 00 model pcm that i bought from dub silverado,it was supposed to be a nelson tune,and supposed to be unlocked, but it runs like **** and its locked.matt and nick were gonna fix it for me but it was locked so the ycant, we did run a log on it while driving down the interstat a lil bit ans i had some bad knock issues. so i still have my stock 99 pcm that came in my truck. im gonna bring it to futral to program the 99,when i get my e fans in the mail.
Old Jan 4, 2007 | 02:55 PM
foff667's Avatar
LS1TECH Sponsor
can someone post a stock 99 truck tune vs a their stock 02 truck tune? I'd like to take a look at the overall differences.
blownss27
Aug 14, 2020 08:27 AM
Cowboy Tom
Sep 5, 2015 04:29 PM
Alco
Sep 4, 2015 04:08 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
USMCvet0311
Aug 1, 2015 07:45 AM
