pcm questions
Old Jan 2, 2007 | 01:29 PM
jaegmc99's Avatar
Default pcm questions
Ok, I'm going to buy Hptuners, one question. My truck is a 99. I've heard of people getting the 02 pcm because it is better or more up to date the the 99. Should I try to find a newer pcm and them use the HPT or just keep what I have and start learning?
Old Jan 2, 2007 | 02:47 PM
foff667's Avatar
LS1TECH Sponsor
your 99 pcm will be just fine.
Old Jan 2, 2007 | 02:56 PM
jaegmc99's Avatar
ok, thats awesome. Thanks
Old Jan 2, 2007 | 06:14 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
no problems with my '00 pcm (supposedly the same as '99s). Talked to a few tuners,and am told that good tuning can eliminate the KR "problems" that people see with these.
Old Jan 2, 2007 | 06:22 PM
sreve's Avatar
'99-'02 the same pcm in trucks and f-bodies
Old Jan 2, 2007 | 08:30 PM
chrisj6's Avatar
99 and 02 are not the same pcm, they do not have the same part #.
Old Jan 2, 2007 | 08:50 PM
getchusum99's Avatar
yep and f-bodies and truck pcms are different also,noyt alot diff but enough to matter, or so i am told, and the 99-00 pcms are different that 01-up truck pcm.s if u do upgrade to a 02 pcm make sure you buy the bigger injectors.
Old Jan 3, 2007 | 02:00 AM
jaegmc99's Avatar
If I find one I'll use it. Got injectors already. Its for a 408 with big cam, 44lbers and a bunch of other ****. If I don't find one I'll just stick with the 99 pcm and tune night and day. Thanks for everyones help and opinions
Old Jan 3, 2007 | 02:31 AM
RandomHero's Avatar
i would get an 02 pcm. The 99-00 pcm's are notorious for having false knock, there is also a few perameters that can't be modified in a 99-00 pcm. I have a 99 as well and I bought an 02 pcm for my truck when I got EFI live.
Old Jan 3, 2007 | 07:03 AM
foff667's Avatar
LS1TECH Sponsor
the pcm itself has no way of causing false knock, sensitivity settings yes, but the pcm itself no, yes the 99's have slightly fewer parameters you can change as compared to a later model pcm as well as having slightly less resolution in some cases. Other then that 99 pcm's are fine though.
