P01-0411 Has me stumped- no spark/no fuel on different cylinders
Old Jun 28, 2022 | 09:25 PM
  #81
Bgbldodge's Avatar
Always loved the c5’s. Super jealous.
Old Jun 28, 2022 | 09:47 PM
  #82
shakenfake's Avatar
Shlumpt
5 Year Member
Agree with above
Old Jun 28, 2022 | 10:57 PM
  #83
1FastBrick's Avatar
Custm2500's Rude Friend
Looking good! Congrats on the repair.
Old Jun 28, 2022 | 11:04 PM
  #84
arthursc2's Avatar
Don't be too jealous yet
there's an oil leak I think might be rear main
there's an AC leak on the brand new OEM condenser and high pressure line connection. I think I can fix it with welding
perpetual leak on the passenger long tube to x-pipe
PS and coolant both had leaks I think were fixed by tightening clamps
it's been a mission. Lots of little **** happening that's frustrating me
Old Jun 28, 2022 | 11:09 PM
  #85
arthursc2's Avatar
Ton of torque tube/ throw out bearing noise too. Ultra irritating because I measured the TOB spacing and rebuilt the torque tube while this thing was apart for 3yrs
Old Jun 29, 2022 | 08:04 AM
  #86
arthursc2's Avatar
Coolant leak and PS leak seem to be fixed via tightening clamps more
Exhaust leak is going to get wrapped in copper foil and reclamped. Hoping the conformal foil will help the band clamp seal
AC leak is a failed braze joint. Going to sweat that fitting off, clean off the braze and weld it up. Because #welderlife. Not going to deal with the return and BS of that hassle. Can fix it in the same time I'd probably need to write the return info up
RE;oil leak and TOB noise- if the leak is the rear main (its not the oil pressure sender) then its just gonna stay like that for a while. When I pull the trans/torque tube to remove clutch to do the leak, I will also fix the TOB noise. If I rest my foot on the clutch pedal at idle, its silent- so thats my fix for now. This car will get driven 5-7k yr at most, so I am not too worried. But they won't be easy miles. Maybe I should be worried lol
Old Jun 29, 2022 | 08:51 AM
  #87
MikeGyver's Avatar
Won't the rear main seal leak eventually quiet the throw out bearing by lubricating it? And help your clutch slip by soaking the plates in oil? You have to look at the positive side of having a leak.
And is your condenser steel? Or did they use alumaloy to braze it?
Old Jun 29, 2022 | 09:13 AM
  #88
arthursc2's Avatar
I actually don't know what it's brazed with, it's a black color braze though. Maybe epoxy?
condenser is aluminum
Old Jun 30, 2022 | 08:36 AM
  #89
MikeGyver's Avatar
I had to look at my aftermarket aluminum condenser last evening. Duh, of course it's brazed. How else could they join those tiny tubes to the headers. They must furnace braze everything at once.
I'm interested in how you go about repairing yours.
Old Jul 2, 2022 | 10:29 AM
  #90
arthursc2's Avatar
Real-time repair, condenser is out. Here is the leaking POS
