O2's burnt up??
Old Mar 11, 2007 | 06:48 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default O2's burnt up??
How can I tell if my O2 sensors are shot? my mileage has gone to about 10-12 mpg and my truck is rich, rich, rich... I know having no cats, I'll be able to smell more exhaust but if I stand behind my truck while its running it fumes you out... the truck has about 100K on it now and has quite a few bottles of nitrous through it at this point...
-my problem is I dont have tuning software so I cant get voltage readings or anything. my SES light has been on forever now and here letely it has started flashing... can someone point me in the right direction??
-EDIT: these are my fronts. My rears have been turned off and removed with my ORY.
Old Mar 11, 2007 | 07:14 PM
03sierraslt's Avatar
If your SES light is on what is the code?
Old Mar 12, 2007 | 06:46 AM
Hunt&Fisherator
I was getting lean codes from both banks... I dont get that though because its running super rich right now.
Old Mar 12, 2007 | 10:31 AM
dewmanshu's Avatar
Moderately Differentiated
"was" as in when? did they go from lean code to rich like right away. Or did the truck slowly drift to rich.
In a nutshell, if you have 100K on stock NB02's, it wouldn't hurt to replace them. Maybe the wallet, but 100K is alot.
I have screwed mine all up, splicing and what not, but on yours the harness is different form front to rear correct? if not just swap the rears to the front and see if it makes a difference. But I don't think you can do that. Unfortunately, replacing them is a good place to start with such high mileage on them.
Old Mar 12, 2007 | 11:13 AM
Hunt&Fisherator
its always been a bit rich since the first time I had it tuned... it steadily worked its way richer though... Yet another W4M disaster... I'm biding my time until I can get back to Texas and have Wheatley tune it for me.
I guess "was" refers to before my retune... since I got it back it is a little worse... I suspect he put a lot of fuel in it due to the cam... but the O2's have to be struggling too... I have had it tuned 3 or 4 times now by him and each time it gets a little worse... now, at idle, there's raw fuel spitting out of my dump tip...
Old Mar 12, 2007 | 11:27 AM
dewmanshu's Avatar
sounds tuning, but if you had lean codes...hmmm. Standing behind your truck with No cats by the way will choke you up big time and your afr can be 15:1. Just a note. I idle at 14.68 and you can't stand behind truck w/no cats too long.
Old Mar 12, 2007 | 11:30 AM
dewmanshu's Avatar
yeah, too rich will shorten the life of 02's. If you have fuel coming through the exhaust..WOW, you might want to do something about it. Washing down those cylinders isn't to good of an idea. If it is ***** too rich, it would bog everywhere.
Old Mar 12, 2007 | 11:37 AM
Hunt&Fisherator
yeah... I guess I need someone locally who can tune a 2000 VIN..... I crawled under it idling to look at the rear and I got out hacking and choking... thats when I noticed the exhaust... I wiped it and it smelled just like raw gas but in all honesty I could just be over reacting... it may be condensation. ... I guess its time for O2's then... what about MAF or anything else? I know thy dont often fail but would it cause a rich condition? I have a stock LS1 MAF I could throw on it if need be.
ferrellrooster
Mar 6, 2025 03:22 PM
fortune46x
Sep 16, 2015 08:18 AM
Zacholcomb
Sep 3, 2015 06:14 PM
MileHighSierra
Jul 22, 2015 11:19 PM
