need some help, flashing stock tune back...
Hey guys, I am trying to convert back from a 2bar/80e tune to the stock maf/80e tune that has had a segment swap applied to it. I am running stock ls2 32lb injectors, not the 24s that came with the truck.
Everything works perfectly with the 2bar tune, but when I do a write entire using the maf/80e tune and switch the MAP sensors the truck will start and idle but is extremely lean (wb shows 18ish), and if I force it into closed loop the trims go to +50 and its still slightly lean around 15. I thought the injector data might be off but they are exactly the same, both tunes have the 32lb injector data...any help would be appreciated.
Here are the files i attached on the hpt forum
thanks
thanks
Then why do they work so well on 32lb injector data on the 2bar tune? The part number on them says they are stock ls2 injectors.
The only thing I change on the truck between tunes is the map sensor back to the stock one.
The two tunes that you posted on HPTuners forum are vastly different. There is much more different than just reenabling the MAF. Are you still running roced induction?
No, its a stock vehicle now except for the 80e swap. The only difference between the maf/80e tune and a stock tune for a 5.3 truck should be the spark table, 80e segment swap, TM stuff, and injector data.
I compared the tune I was trying to use to one I had before I did my cam (ie, stock) and the ve table is within 4% so I dont think thats the issue since trims are +50%
I had a truck in the shop last week, fuel trims were +50% on bank one only. It had a bad O2 sensor(B1 S1).
Ill give it a try later for ***** and giggles I guess.
I would suspect O2s as well if my wideband wasnt telling me lean and they work fine on another tune...
