need help diagnosing my terrible misfire!
Old Oct 8, 2011 | 02:54 AM
SmokinHot98's Avatar
Default need help diagnosing my terrible misfire!
It started last week, I put SHITGO premium gas from the hood bc the price was cheap. I ran a whole new tank of 93 from Shell along w/HEET and seafoam and it still misfired.
Today I changed the plugs w/NGK Iridium and the o2's back to new stock Delphi ones bc I was having o2 DTC codes like crazy . It ran GREAT and then started misfiring 15 minutes later on my way to work. They bank 1 plugs (TR5's) looked good but bank 2 was caked in soot, same for the o2's. What could it be?
A friend said he had similar problems when his fuel pump was on the out, but wouldn't it cause misfires on all cylinders not just 1 bank?
these were my common codes:
P0155
P0300
P0442
P0135
P0174
P0151
The drive home was terrible!! A co-worker followed me some what, and I could see the smoke pouring out. I went through a 1/4 tank and was popping like crazy. But it was intermittent, it would misfire then stop and then start misfiring again.... oh and no other codes besides the P0300 - multiple misfire one came on
Thanks
Old Oct 8, 2011 | 10:49 AM
P0155
P0300
P0442
P0135
P0174
P0151
Thanks
Old Oct 8, 2011 | 12:24 PM
Fastcount03's Avatar
That is what my 02 did when the fuel pump went out, but the one bank thing is kinda fishy.
Old Oct 8, 2011 | 12:53 PM
TTownTech's Avatar
Def need to check fuel pressure. do you still have cats?? the tr5s are quite a bit colder so def not hot enough to self clean. Backfiring or running bad at all would probably foul them pretty quickly. so I doubt they are your problem just an after effect
Old Oct 8, 2011 | 02:14 PM
exactly, I could understand if it was but the one bank think is losing me too
Old Oct 8, 2011 | 02:16 PM
I'll try to check the FP tomorrow. No the cats have been eliminated
Old Oct 8, 2011 | 02:42 PM
Third Gear's Avatar
A lot of codes there friend. Seems like they are all emission/O2 related. What's up with the tune - do you have tuning software? That could help you a lot. It would be great if you could force it into open loop - or just to see if MAF, MAP, etc are operating correctly.
TR5s are stock heat range, ignore that.
Fuel pressure is a good idea.
Old Oct 8, 2011 | 03:48 PM
Suddog's Avatar
With your new software, run a log. Any exhaust leaks?
Old Oct 9, 2011 | 03:08 AM
after reading one of my logs on HPT, my bank 2 o2 isn't running.... I'm gonna try a crank relearn tomorrow and hope it helps.
Any other suggestions on what caused it or how to fix it?
Old Oct 9, 2011 | 03:36 AM
Sorry CASE relearn*
These are brand new o2's if you missed it up top!
