My 2011 5.3 is way rich!
Old Jan 6, 2012 | 07:52 PM
Larry's Avatar
Corvette & Mustang Moderator
Default My 2011 5.3 is way rich!
New 2011 5.3 Silverado, 510 miles. Commanded AFR of 10.8 and as little as about 21* of timing in some frames! I don't have a wide band on it but if commaned is actual then GM has tuned this engine awfully rich. My truck could use a tune!
File Type: hpl
Old Jan 6, 2012 | 08:13 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yep, and the 6.2's are like that too. They've detuned the **** out of them.
Old Jan 6, 2012 | 08:32 PM
Larry's Avatar
Yep, I'm sure the 6.2s are about detuned about the same. For GM to give these trucks a 100K mile warranty I suppose they have to be very conservative.
Gut my third cat that seems to me almost redundant, give it a good 93 octane tune and I might pick up a few horses.
Old Jan 7, 2012 | 01:12 AM
As redundant as it seems initially, these new trucks run so ******* rich when in PE, that I could see them NEEDING the 3rd cat....
Old Jan 7, 2012 | 06:11 AM
Larry's Avatar
Good point! And even when not in PE notice the 14.37 commanded at idle/part throttle vs. 14.68 normally.
Old Jan 7, 2012 | 08:15 AM
CalEditor@PCMCalibrators's Avatar
FormerVendor
What is the Ethanol % displayed in the log?
14.37 should be about 7%.
Old Jan 7, 2012 | 08:37 AM
Larry's Avatar
Is there a PID for Ethanol %? I'm not finding it if there is.
The pump that I bought gas says up to 10% Ethanol I believe. However my Corvette always shows a commanded 14.68. I did buy 89 octane and always 93 with my Corvette. Maybe a difference???
Old Jan 7, 2012 | 10:17 AM
Rhino79's Avatar
9 Second Club
Normally I have seen they are a little leaner than the commanded. The stock maf calibration is not dead nuts accurate.
Old Jan 7, 2012 | 10:52 PM
superwagon's Avatar
Pretty sure that 7% should be more like 14.27 and is your corvette e-85? If not it will command the 0% ethanol content and your fueling will have that E?% error from the start.
Old Jan 8, 2012 | 06:09 AM
Larry's Avatar
I use 93 octane in the Corvette from the same Chevron station I bought the 89 for the truck.
I'm going to try 93 in the truck and see if anything changes.
Cowboy Tom
24
Feb 11, 2017 08:20 PM
wrb002
Aug 25, 2015 03:56 PM
silverstreak07
Aug 23, 2015 07:09 PM
06 4.8
Aug 21, 2015 11:33 PM
Matt331
Jul 26, 2015 09:40 PM
